Question about rear leaf springs and F150 vs F250 - Ford Truck Enthusiasts Forums
Old 06-02-2014, 09:25 AM
joegeds joegeds is offline
joegeds is gaining momentum as a positive member of FTE.
I have a '96 F150 and the rear springs look a little tired. My truck sits way low when not very much weight is put in the bed (700 or so lbs). So I am looking at new leaf springs. I see on Jeffs Bronco Graveyard website that they offer 5 different stock leaf springs:
F150 4x4 - 1700 lbs/spring
F150 4x4 - 1389 lbs/spring
F150 2x4 - 1660 lbs/spring
F250 - 2450 lbs/spring
F250/F350 - 2977 lbs/spring
So, I have a couple of questions.
1) Do leaf springs "go bad", ie - lose their "springiness"?
2) Will the F250 and F250/F350 springs fit my truck?
3) If I want to increase weight capacity of the bed, is it as simple as installing the 2977 lbs/spring leaf springs (or if they don't fit, just install the heaviest capacity ones that will fit)?
4) Would adding these heavier-duty springs possibly hurt my rear axle/internal parts (like bearings, etc)?
5) Per the label on my door jamb, my GVWR is 6250, rear axle GAWR is 3776. Are those weights set by the factory springs that were installed, or some other criteria? In other words, is the 3776 number set because springs that are rated at 1888 lbs/spring (half of 3776) were what was installed at factory?
Old 06-02-2014, 01:00 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Springs don't really change their "springiness" much, but they do sag so they sit lower all of the time. If you put an additional 700 lbs on new springs or old springs the truck would settle down about the same amount, but with old springs it will be starting lower so the squatted height will be lower as well.
I don't know if F-250/F-350 springs will fit your F-150. The biggest issue I could forsee is spring width. If the F-250 springs are wider they won't fit into the F-150 brackets. Not sure if they are, just what I'd be looking for. New hangers on the frame, new U-bolts and plates, and new shackels for an F-250 would address that (IF it's necessary).
If the F-250 springs aren't a direct drop-in a local spring shop could probably make you up a set of heavier springs that would fit if you could tell them what you wanted.
The heavier springs won't hurt anything on your truck (other than the ride). But if because of the springs you carry heavier loads, that could cause additional wear and/or breakage if you end up overloading other components.
Old 06-02-2014, 01:38 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
4x4 F150 will have 3" wide springs, same as the F250 & F350. My truck was in the same condition, I put factory rated springs in for replacements and it was much much firmer. The old springs were shot, sagging and soft. 1000lbs put it on the bump stops and felt overloaded, now 1000lbs gives about 3" sag and doesn't feel overloaded. The F250 & F350 springs would probably lift the back of the truck a bunch too.
The axle itself and the wheels/tires would be some of the first limiting components other than the springs, next may be the frame.
Rear leaf spring replacement questions... Sous 1999 - 2003 7.3L Power Stroke Diesel 20 05-11-2015 08:37 AM
Rear leaf springs joegeds 1987 - 1996 F150 & Larger F-Series Trucks 9 11-21-2014 02:38 PM
Question re: Allowable weight in bed joegeds 1987 - 1996 F150 & Larger F-Series Trucks 2 07-09-2013 02:34 PM
Spring Codes skyfox10 1987 - 1996 F150 & Larger F-Series Trucks 0 10-23-2010 02:54 AM
Leaf Springs F250 SD smoking colorado 1999 to 2016 Super Duty 5 07-12-2008 05:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
