96 efi 460 performance
on
Thank you mflo, I was unaware.
Ok ill take a look tomorrow. I have another question. It first started on just my rear tank but now both are doing it if it sits all day at work or overnight it will fire up and die several times before it will actually stay running. Like the fuel is bleeding all the way back to the tanks. Any ideas what would cause that? And could that have something to do with my lack of power? My truck is a gas guzzling gutless land yacht.
on
I don't have much exp. with this but my guess is that your sending units are shot or your sender relay is. How long did you drive it on one tank?
Don't blow your money on a K&N or other "performance" filter. All it will do is lighten your wallet and allow more dirt and sediment into your engine. If you had a race engine turning 7500 RPM then it would be a good choice, however a plain paper filter will flow more than enough for what you have.
Performance help
Sorry if posted the wrong way or in the wrong plus this is my first post on here I have a 96 f350 4x4 crew cab 460 efi with a zf5 Trans I am looking for some power increase and performance already have aftermarket exhaust but other then that it stock healthy but no other performance parts any ways I use it for hauling and towing plus it's just a fun truck to drive but would like to get more power and it would be nice to see better fuel mileage but I don't expect to get 20 mpg any suggestions would be appreciated I have been looking into performance chips but can't find one that I know will work
on
Set base timing to 12 degrees btdc. Remove spout connector on the inner driver fender before setting timing. Best bang for your buck.
cchimuk
07-22-2009 05:52 AM
