power number difference questions - Ford Truck Enthusiasts Forums
Old 06-01-2014, 11:10 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
I know the f series in 08 for the 5.4 was rated at 300hp. I also know in 09 it was bumped to 310.
1) so for 08 I've visually compared the 150 to the superduty and the superduty has a bigger intake and exhaust so my thinking is it should have more power. Right or no?
2) did the 09 superduty have 310hp?
3) what caused the power bump?
4) why is the 6.2 rated at 411 for the 150 and 385 for the superduty but the 5.4 was rated the same for both?
Just some things I've thought about. Thanks for any input
Old 06-02-2014, 04:23 PM
nojoke327's Avatar
Anyone
Old 06-17-2014, 02:01 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
I don't have any for sure answers but it could be as simple as factory settings in the pcm. 10 horsepower is not alot of difference from a 5.4 liter V8. On the 6.2 the intake and pcm settings could be different in the superduty and be more for torque than horsepower.
Old 06-18-2014, 09:50 PM
nojoke327's Avatar
Quote:
10 hp definitely isn't a lot but the superduty has a much bigger exhaust and better intake so I figured it had to have "more" power.
Old 09-16-2014, 09:32 PM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.
F-250 is detuned for longevity. The 6.2 in an F-250 is meant to pull 13K pounds all day long without overheating the pistons and block. The detuning gives that headroom. The F-150 is not designed with that punishment in mind, so they have a bit more headroom on the tune to play the numbers game with other manufacturers.
super duty van rv build up for towing. 25,000lbs mrp669 1999 - 2003 7.3L Power Stroke Diesel 41 01-04-2017 09:26 AM
Overall hp ratings 5.8 cam specs stock JRS2 1987 - 1996 F150 & Larger F-Series Trucks 7 07-22-2016 05:25 PM
compatibility issue with superduty and f150 5.4l 3 valve marino1958 1999 to 2016 Super Duty 2 04-13-2016 05:35 PM
Excursion and a 5.0 Cummins... Any thoughts? Ardiemus Excursion - King of SUVs 19 04-19-2015 07:16 PM
Flow rate of stock fuel pump on 08 6.4L ktheavner 6.4L Power Stroke Diesel 10 05-12-2014 08:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
