Not a Mechanic But?
Was talking to a guy today while I was at the tire shop getting my work van tire fixed. He had a 02 7.3 he mention that there is a sleeve that can fall down the engine when changing out injectors. If that happens got to pull top of engine apart to get it out. Hopefully that's just a PSD issue. Or he's talking crap!
There's not much that can go wrong, really. As long as your parts all come out, and the new ones go in where they should, you'll be fine.
You can pick up a book on this engine at the local autoparts store -- the book covers our IDIs, the Chevy 6.5, and the 7.3 powerstroke.
IIRC, it's a Chilton book.
Well today I went ahead and tested my glow plugs on the truck. Only 3 were good. So I'm going to order new ones ASAP! I was testing the supply voltage Not sure what went wrong but only getting .438 reading on the multimeter. (auto meter) according to my book it should be the yellow wires in the picture.
I also have no idea where the ground wire is suppose to be screwed into.
What is this screen called so I can get a new one?
Thanks
Michael
Thanks
Michael
I had the same problem with mine but it was concentrated at the passenger front side. Turned out it was my fuel filter. Both the bowl and the heater plug was leaking. Replaced the o rings on the fuel heater and replaced the fuel filter with a one piece and odor went away.
However, the fact that you have oil(it's usually diesel, actually) there indicates a problem(usually the damned o-rings).
#28
HELP!
Sorry guys I need help again . I was driving the truck this even when I turned it felt like the front end jerk and shifted making a pop noise. I know it's not tie rods just did those. I believe it's ball joints. As I was researching I can't find a lower ball joint for my truck. (91 F350 4x4 CC N/T) Is that due to it being a 4x4?
Is this something I can handle or should I take it to a shop?
Just let you know what I managed so far..
( I did my own tie rods, injectors, glow pugs, and return lines)
Would you mind making a parts list and name of a good brand. I have Moog tie rods if that helps any
Thank you
Michael
Thank you
Michael
#30
Nope not sure! according to my haynes book they call ball joints but when I try to shop for them on line (rockautoparts) I only find uppers and no lowers for the 4WD trucks???
