Did 1969 F250 wheel cover question
Did the 1969 F250 4 wheel drives come with factory wheel covers? I can not seem to find a photo anywhere. I just picked this truck up and will probably be asking a lot of question, so I apologize in advance. I love the old truck but would really like to put some factory wheels and hubcaps on if possible. It seems that if there is such a thing they must be hard to come by.
Thanks,
Jeremy
Thanks,
Jeremy
Wheel cover available for F250 2WD & 4WD (rear only) for the first time beginning in 1972.
D2AZ-1130-J (replaced D1AZ-1130-A) .. 15" Wheel Cover / Obsolete
Applications: 1971/72 Galaxie/LTD / 1972/74 E300 / 1972/77 F250/350 / 1975/77 E250/350.
D2TZ-1210-A .. 16" Trim (aka beauty) Ring / Obsolete
This trim ring was snapped onto the wheel first, then the 15" wheel cover was snapped onto the trim ring!
And btw, there was no 16" F250 4WD front hub cap available (with a center hole to allow the hub to poke thru) until 1984.
None listed for 1953/71 F250 2WD, 1959/71 F250 4WD.
Wheel cover available for F250 2WD & 4WD (rear only) beginning in 1972.
He asks about wheel covers and then expresses that he wants to install 'factory wheels and hubcaps'.
I was just referring to any type of ornamentation on the wheel. I have seen a 1970 and a 1971 at car shows that appear to have used Bronco wheel covers. That was a long time ago though and I am guessing they must have been on 15 inch rims. Thank you all for your information, I really appreciate all of the help.
BlueWhiteFord
08-04-2019 03:03 AM
foxeswaltz
11-03-2018 11:36 AM
