Edge Evolution CS - Ford Truck Enthusiasts Forums
Edge Evolution CS
Old 06-01-2014, 05:24 PM
Duderoy's Avatar
Duderoy Duderoy is offline
Duderoy is starting off with a positive reputation.
Edge Evolution CS
Does anyone have any experience with these? They list specific results for your vehicle and they say my 2007 F150 w 5.4l will gain 35hp and 45fp torque. I hope these results are correct because for $440 it sounds very worth it. Would LOVE to here any feedback on this unit.
Old 06-05-2014, 11:06 AM
Scottwoo's Avatar
Scottwoo Scottwoo is offline
Scottwoo is starting off with a positive reputation.
Edge products suck IMO. Had one on my Excursion and caused all kinds of problems, finally had to rip it all out and go back stock. Also have one on my 02 c/c and it has worked ok. Causes the truck to hiccup during driving sometimes. Not a big fan of Edge, but both of mine are diesels.
Old 07-01-2014, 01:39 PM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
I also had the Edge mess up my 150 so badly that the module had to be changed and flashed. The Edge forced the ABS dash light to remain on. This programmer might be ok if truck is completely stock but sucks once lifted, larger wheels and gears are changed. Spend the extra money on a programmer from 5 Star or PHP with custom tunes.
Old 07-01-2014, 04:25 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Your best best is going to be with tunes that are custom. As was already mentioned, if you are to change out other things, it won't be able to compensate. Also bare in mind, the tunes that are on your Edge, Bully Dog, Banks etc are one size fits all type of tunes. Some like how vehicle handles with the tunes, some do not.
Going custom (as long as you go to a reputable tuner (person)), precludes that and plus it gives you the ability to expand later if needed.
Quote:
If it's the Ex in your siggy, off the shelf tuners were not kind to the 6.0s. On mine, I had a Bully Dog and my truck didn't care too much for it. But I had to get rid of it anyway, because it wouldn't have been able to compensate for all the other mods that I was planning for it as well.
Quote:
Very very true. You get what you pay for that's for sure.
If you want to do this type of stuff on your truck, but you have very real budget concerns, I would advise against doing this. You run a very high risk that something will break on your truck and if you are unable to set aside money for the fies), then I just wouldn't do it.
Old 07-01-2014, 05:06 PM
tjcprop's Avatar
Oh I have the money. Just replaced upgraded my tranny. Next will be the engine.
1997 F250 7.5l Cranks fine sometimes won't start right away av8rdav Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 07-12-2016 08:32 AM
ANY luck with an aluminum radiator? norm805 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 11-18-2015 04:17 AM
Effect of emission controls j66b 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-14-2015 01:55 PM
Which year F250/350 Leaf Springs for Excursion Swap? Kongerup Excursion - King of SUVs 17 03-20-2015 03:42 AM
In this picture, what is this part called? Larry Wall 1994.5 - 1997 7.3L Power Stroke Diesel 8 12-04-2014 03:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
