cruise control not working - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-01-2014, 04:56 PM
wburge wburge is offline
wburge is starting off with a positive reputation.
I have a 2008 6.4 f-250 FX4. the cruise did work at one time and then worked on and off and now not at all. I have changed the pressure switch at the master cylinder and still not fixed. Is there a brake pedal switch as well? does anyone have any suggestions?
Old 06-01-2014, 05:02 PM
Oh forgot to mention there are no DTC's
Old 06-02-2014, 01:39 PM
fedman1 fedman1 is offline
fedman1 is starting off with a positive reputation.
I had the same exact problem and replacing the forward switch on the master cylinder promptly fixed it. It is a very easy process and the switch cost about $40. I believe that I used a 3/4 inch crowsfoot. Took about 5 minutes.
Old 06-03-2014, 06:46 AM
ssharber's Avatar
ssharber ssharber is offline
ssharber has a good reputation on FTE.ssharber has a good reputation on FTE.
The part # is 3L3Z-9F924-AB. It is called the Cruise Control Cutout Switch and the link for the part at Ford is http://www.fordparts.com/Commerce/Ca...F924-AB#Search.
This can be a confusing one as the pressure switch is right behind the cutout switch. A diagram will be with the link above.
It was $54.41, but Ford charged me $100.00 to replace it, and it's very simple to replace. I just didn't know what it was til they diagnosed it. Maybe you can replace yours and save a hundred bucks.
If what you replaced is the same part # as above, then there is a switch under the dash called the "Brake Deactivation Switch Connector" right above the accelerator pedal that can often go out and cause the cruise to think the brake pedal is being applied. Don't have the part # on that one but you can search the Ford parts page and find it.
Hope this helps.
Old 06-14-2014, 12:59 PM
pugster pugster is offline
pugster is starting off with a positive reputation.
disconnect & clean off the area, then reconnect before you replace anything. I had this problem about a year ago and someone on FTE recommended this. Saved me the money & eliminated the problem since that time.
Old 08-06-2014, 03:28 PM
auriferous auriferous is offline
auriferous is gaining momentum as a positive member of FTE.
Chased the brake switch under the dash and she still works when she wants to!
Old 09-11-2014, 10:44 AM
SWNBilly SWNBilly is offline
SWNBilly is starting off with a positive reputation.
does your truck have adjustable pedals?
I had this same issue. My truck was at the dealership for 7 days! They said they fixed it but cruise still didnt work when I got it back? so I had to figure it out myself. Check up over the brake pedal and make sure no wiring or wire looms are touching the brake pedal at all, if you have adjustable pedals make sure they clear all the way out and in. any pressure on the brake pedal arm will will not allow the cruise to be set, and/or cancel the cruise. This is what my issue was, the factory wire loom was touching the brake arm when pedal was adjusted out to a certain point.
No cruise. No horn. No factory air bags wevie 1987 - 1996 F150 & Larger F-Series Trucks 13 11-02-2016 07:13 PM
'94 Bronco Cruise control inop My4Fordtrucks 1987 - 1996 F150 & Larger F-Series Trucks 9 06-26-2015 09:31 PM
2002 Ford Expedition Cruise Control Not Working hawesra 1997-2006 Expedition & Navigator 2 07-21-2014 09:01 PM
Found a Bronco wit AT and cruise is it worth it to install cruise on my 4-sp? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 03-04-2014 06:27 PM
can i bypass the master cylinder cruise switch? SatisTraction 1997 - 2003 F150 11 02-04-2014 08:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
