1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 f250 5.4 4wd running rough
Old 06-01-2014, 01:44 PM
mcdowellj's Avatar
mcdowellj
mcdowellj is offline
Hello my name is James and this is my first ford. I bought it and changed the fuel filter and it was dirty. Then ran a tank of gas with seafoam and then with lucas fuel injector cleaner. Still nothing. It idles like its missing and as long as you are light on the pedal it revs up fine but if you're heavy on the throttle its ****ty. Its has no codes that's why I haven't replaced the coil packs and plugs but they have been ordered. I just thought there would be an engine code if any of the coils or plugs were bad. Looked for a vacuum leak but couldn't find any. The donut gasket on the pass side is bad would that cause it to run shifty with no code. Any help is greatly appreciated
Old 06-02-2014, 01:32 AM
pathf350's Avatar
pathf350
pathf350 is offline
Hope somebody has better answer than mine but here goes. I picked up a used rental with a ton of miles on it. Ran some Seafoam thru it, probably first time it ever seen any cleaner. Started to run rough maybe 100 miles later then thru a mis-fire code. Turned out Seafoam maybe cleaned it out to good. Fouled injector. Then some miles after getting fuel injector cleaned it later did same thing again. Both were on passenger side second hole back for some reason.
I now change fuel filter every 3,500 miles and no more problems (so far).
Fuel injector shop where I go loves Seafoam, keeps him in business, he has many stories.
I also checked other stuff (COP, COP connections, cleaned MAF etc) before blindly removing fuel injector.
There is a good write up on changing plugs on this forum somewhere, it came in real handy for me. Don't know where to locate it now though. Maybe a search.
Old 06-02-2014, 05:56 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
welcome to FTE.
if it is only an occasional misfire, it will take time ot throw a code.
sometimes my crown vic and 04 5.4 powered F-350 will run bad for a month before it throws a fault code so i can change the coil.
kpchambers
2009 - 2014 F150
34
02-24-2015 01:28 AM
natsoundup
1997-2006 Expedition & Navigator
07-01-2007 03:45 PM
Crush
1997 - 2003 F150
03-27-2007 04:08 PM
perplexed
1997 - 2003 F150
07-08-2004 12:22 PM
lrk_nm_2002
Modular V8 (4.6L, 5.4L)
11-12-2002 05:55 PM
Quick Reply: 2003 f250 5.4 4wd running rough
