1994/1995 E4OD compatability / diodes
Old 06-01-2014, 12:28 PM
SteelHorse4x4's Avatar
SteelHorse4x4
SteelHorse4x4 is offline
Quick question guys. Doing the MAF conversion and my computer is from a 95 Cali Bronco. My truck is a 94. I know they moved the diodes from the trans to the computer in 95, which leads to my question. Can the 94 trans work with the 95 computer, or do i need to change the solenoid pack in the trans?
Old 06-01-2014, 12:39 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Your truck will actually be doubly protected. No problems at all.
Old 06-01-2014, 03:13 PM
SteelHorse4x4
Yea, I kind thought that but mind is somewhat frazzled right now. Putting a 95 Cali Bronco PCM in and not doing an overlay. Got a MAF harness and pulled all the wires to "C103" connector and re-pinned everything. Pulled distribution box up and put everything in factory harness. Added second HEGO also. Next wknd will be the engine harness swap and changing EGR and tube for the DPFE sensor etc. gonna have nightmares about being attacked by wire, lol.
Old 06-01-2014, 06:30 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,152 Likes on 910 Posts
As Lead Head stated, you will have double protection diodes. Is that a bad thing? Probably not, but it is better than none at all.
Sk8rbrdly11
07-18-2016 09:35 AM
jbas
01-12-2016 09:27 PM
f150truckguy
05-29-2014 12:27 AM
SteelHorse4x4
18
03-29-2014 06:51 PM
hivoltj
06-06-2012 12:01 PM
Quick Reply: 1994/1995 E4OD compatability / diodes
