Larger Oil Filter
Many times a physically larger filter actually doesn't have a higher capacity for trapping dirt. Lots of other factors go into filter capacity, like type of filter media, how it is fit to the case, number and size of pleats in a pleated media, etcetera.
So, without a full breakdown of all the filter facts, that larger filter may not be any better than the original.
You can always get a remote kit that uses double filters.
Why would you want a bigger oil filter? Ford has spent millions on R&D on the 6.2L. A larger filter does not equal more filtration. The S means there is a silicone anti drainback valve present to eliminate dry starts.
The 820s is the most widely used oil filter in Fords lineup. I can't see a problem with it. Look at police cars, those 4.6l motors use the same filter and go 200,000-300,000 miles with little oil related issues.
I don't buy off on the premise that these vehicles are equipped with the best of anything. It's all a compromise with the bean counters and the engineers. It all comes down to one oil filter costing .10 less than another. If the cheaper filter will work, that's what we get. That's business.
But I figure, if a 820s works for the raptor, it should be fine for our needs.
Awesome info. I always wondered the significance of the 'S'. Wonder what the 'FL-1A' means? On a side note, the local oil joint I frequent uses Security brand oil filters, and my 3 Liter V6 Ranger has a size '36000A'.
Yeah...they also spent millions developing the 6.0. Did you see how that turned out?
As long as you don't do a bunch of short trips (the oil will never get to operating temp) adding more oil capacity is always a good thing. Even if there is no extra filter media.
More oil is always good for an engine. It stays cleaner and cooler. That's why the big trucks with the 6.0 take even more oil than a Super Duty.
Just because Ford did it doesn't prove anything. Ford has done a lot of stupid things over the years.
The only time it ever becomes an issue is if there is too much oil, it takes too long to get hot. If you only drive short trips, more oil can hurt you. Otherwise it is always beneficial.
Stop trying to argue.
I'm not sure what that has to do with anything. I know how they work. All engines will benefit from a larger oil supply. I never specified a type. I said all engines.
