EFI STARTER
These folks sell a mini starter that fits '65 - '96 300s, so reasonable to assume how the starter mounts didn't change throughout the run of the engine.
DB Electrical - FORD F TRUCK BRONCO 4.9L 300 6CYL NEW STARTER 1965-1996 3223 SFD0012
The good news is that this concept should lessen the chance of the old-style fender-well solenoid seizing up and running your starter constantly. (not as much amperage needed to flow thru it...it's done down below.)
The new starter is a permanent magnet design that Ford went to in the late 80's and 90's for most of their products I believe. It works similar to gm style utilizing a constant hot feed to the massive solenoid down below, then actuating it by a smaller lead from the fender-well solenoid. Good starter, just needs a little wiring. The diagrams are all over the net.
Info here.
https://www.ford-trucks.com/forums/8...-opinions.html
Info here.
How To Properly Wire Your PMGR Mini-Starter - FSB Forums
It appears that 1992 is the first model year for the smaller high density permanent magnet design with integrated solenoid.
The pinion gear on this smaller starter has 10 teeth.
The previous larger starter design has 9 teeth.
Looked up the tooth count on the flywheel and flexplate for 1982 & 1992
Both 1982 & 1992 have 164 teeth with 12 pitch, 14.23" outside diameter.
The 10 tooth pinion must be larger in diameter than the 9 tooth pinion to mesh with the 164 tooth flywheel/flexplate and therefore, spin the engine slightly faster.
Track Record?
Anyone using these starters? If so, how well have they performed?
Thanks, jack
The million dollar question is: Will this starter allow for removal/installation w/o having to remove the intake and header when using a headman header? I certainly like the 40% more torque with far less drain on the battery.
1965GTFB
09-20-2018 06:14 PM
F-250 restorer
06-12-2017 07:39 PM
