Boing, boing, boing....???
Old 05-31-2014, 08:32 PM
beechkingd's Avatar
beechkingd
beechkingd is offline
With my ignition key out and the door open my truck keeps going, boing, boing, boing. Any ideas?
Old 05-31-2014, 08:33 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Headlights on?
Old 05-31-2014, 08:40 PM
beechkingd's Avatar
beechkingd
No they aren't.
Old 05-31-2014, 08:45 PM
eakermeld's Avatar
eakermeld
Somehow the warning chime thinks they are. Probably just unplug it.
Old 05-31-2014, 09:41 PM
Artaxerxes's Avatar
Artaxerxes
Artaxerxes is offline
My key lock cylinder is worn and the truck will buzz at me if it's not left in a particular position after I remove the key and open the door. I'm guessing it thinks it's still either in an on position or in accessory mode. Maybe the same thing is happening to you?
Old 05-31-2014, 09:56 PM
eakermeld's Avatar
eakermeld
It did on my 90. Jabbed a screwdriver thru the buzzer. No more boing. About 6 months later the cylinder broke so if I should have replaced it then but oh well..............
Old 06-01-2014, 01:18 AM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
Where is the buzzer at?
Old 06-01-2014, 07:48 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
In the fuze box to the left of the steering wheel I think.
You might try graphite powder shot into the key cylinder and operate the cylinder a few times to spread the graphite. Might lube it enough to fix the switch that thinks your key is still in the ignition.
Old 06-01-2014, 07:50 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Really?!?!? Follow the NOISE
superduty4x4
18
05-16-2011 10:18 AM
Ford_NDN
05-20-2010 08:44 PM
herman391
1983 - 2012 Ranger & B-Series
05-27-2007 06:00 PM
Johns9163
1997 - 2003 F150
03-13-2005 10:50 AM
Quick Reply: Boing, boing, boing....???
