limited slip differential noise - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-07-2003, 08:15 PM
cdtruckn's Avatar
cdtruckn cdtruckn is offline
cdtruckn is starting off with a positive reputation.
Well found out what caused my LSD noise when I turn hard left or right. DANA. thy assembled the clutch plates wrong. steel,fiber,steel, steel, fiber, two steel plates together It's hard to find good help these day's.:-staun
Old 07-07-2003, 10:07 PM
nitrorod nitrorod is offline
nitrorod is starting off with a positive reputation.
Mine unloaded under heavy load this weekend and was very loud, is this normal for the Dana?
Old 07-07-2003, 10:45 PM
cdtruckn's Avatar
Quote:
No that's what my truck did when I pulled out of the driveway. if you feel any kinda binding or bumping when you leave a stop and turning under a medium throttle you might have the same problem. also check to see if there is any metalflake in the gearlube.
Timing gears roadrash63 Ford Inline Six, 200, 250, 4.9L / 300 5 02-17-2016 09:38 PM
C4 Corvette Front Clip ffracer11 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 11-28-2015 08:42 PM
modified sticker harrah1969 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 05-02-2015 09:37 PM
carbon fiber headliner? weez440 1973 - 1979 F-100 & Larger F-Series Trucks 11 10-07-2014 08:35 PM
Timing gear fun. Jonathan Page 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-09-2014 07:17 PM
Tags
2003, differential, f150, f350, ford, limited, load, lsd, making, noise, noises, slip, trouble, truck, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
