Best trans fluid for AOD
Ford changed most of the specs to V...........as for the science and technical comparisons here's one place to research
The Petroleum Quality Institute of America
(Also just noticed your call sign --- I'm running a 351C in a 1966 "S" Fairlane GT which I've owned for over 25 years---incredible engine (air pump) and it lifts the front wheels on good days......11 second machine in the 1/4 mile without breathing very hard too)
The red kind....
There really isn't a trans fluid that's better than another really. There's plenty of tests that show each fluid in certain situations and which one performs better. Really type f and b&m trick shift perform nearly the same. Mercon V is "the new" ford fluid. It is compatible with all transmissions except ones currently using type f. If it was rebuilt with new seals, and for new fluid, then they can use merconV.
Choose a fluid that's compatible with the seals.
In an aod, I really doubt you'll notice a difference between the 3 and 5.
dotcentral
04-30-2006 12:48 PM
AManAndHisTruck
03-03-2005 06:08 PM
lilwally_90ford
02-04-2005 12:09 PM
whassup28
07-26-2003 06:54 PM
