I ICP reading 3,000psi...
Still have an issue with my 6.0. I changed the fuel pressure regulator yesterday and she's been driving a lot better but still having cold start issues. I'll be checking for high pressure oil leaks this weekend but I wanted to find out if my ICP is reading correctly. I was on the highway drive at 80mpg and 2, 245rpm and the ICP was bouncing between a range of 2,000psi and 3100psi. Is this normal, seems high to me.
I asked you in one of your many other threads what the ICPV's were at KOEO and you never responded, knowing the ICPV's at KOEO will tell you if there is a problem with the ICP sensor. Also was the ICP fluctuation during your 80 MPH cruise with constant pressure on the gas pedal?
I would agree
lots of varibles driving and getting sesor values
get truck hot and check it idle and 2500rpm PARKED
also KOEO numbers a must
Wish you lived a little closer, I'd gladly hook up the AE and get your truck sorted out.
If it is indeed a HPO leak on your '03, there really only are two places that leak and fail, the branch tube fitting at the pump (o-ring where it attaches to the pump) and the HPOP itself. The average life of the HPOP on an '03/early '04 is usually 200-250K then they start to fail if not completely. (Not always the case, but seems to be the consensus) The OEM pumps sometimes aren't that much better so a lot of people opt for the billet Dieselsite pump that addresses the failures for better longevity.
Either way, if you can get a second opinion through a diesel performance shop, you can either confirm the findings or find the actual answer to the problem at a fraction of the cost.
