exhaust control valve - Ford Truck Enthusiasts Forums
Old 05-30-2014, 10:52 PM
wfon's Avatar
wfon wfon is offline
wfon is starting off with a positive reputation.
Is it possible to find a new exhaust control valve? Or just the thermostat part?
The thermostat spring is missing from mine, so the valve is alway open. I have been having some trouble with faulty acceleration from idle when the engine is cold. I think the exhaust control valve is supposed to help with fuel delivery at cold engine temperatures.
Old 06-05-2014, 12:20 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Don't know of anyplace that has a Heat Riser valve for a Y-Block but perhaps you can find another to fit. Maybe from a FE?
Old 06-05-2014, 12:38 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
FoMoCo did not supply the thermostatic spring by itself for the 292, it was only furnished with the valve.
COTE-9A427-A .. Heat Riser Valve / Obsolete
1960/64 F100/700 292 2V
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
Old 06-11-2014, 10:29 AM
wfon's Avatar
Do you have a source for a replacement?
Do I really need it to work?
Old 06-11-2014, 10:19 PM
tomw tomw is online now
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
In my experience, they generally rusted either open or closed. If yours is free, you could rig a manual choke cable to operate it remotely. Personally, I'd invest in a good thermostat, and leave it open.
If rusted closed, you force 1/2 of the exhaust gas to pass through the crossover in the intake manifold.
tom
Old 06-11-2014, 11:05 PM
wfon's Avatar
The valve is free and the weight keeps it open. The spring on the thermostat would keep it closed until the engine heated up enough. It is a failsafe device.
Old 06-12-2014, 07:21 AM
You cannot buy the spring. You were touted a source for a replacement. I suggested a manual operation alternative.
YOu have 3 choices.
do nothing
buy a replacement & install it
rig a workaround
and I suppose, you could take it out altogether. So 4 choices I can think of.
The ones I have seen have a weight that tends to open the valve. The spring gets WEAKER when warm, I think it is a bi-metal, and closes the valve with not much force when cold.
You are lucky it is free to move. Most are rusted into one position.
A 5th choice would be to scour junkyards for another valve. I have nothing else to add.
Old 06-12-2014, 11:24 AM
wfon's Avatar
Quote:
YOu have 3 choices.
do nothing
rig a workaround
The ones I have seen have a weight that tends to open the valve. The spring gets stronger when warm, I think it is a bi-metal, and closes the valve with not much force. You are lucky it is free to move.
The spring keeps the valve closed to warm the intake manifold until the spring heats up and then it relaxes to the open position.
Old 06-12-2014, 03:06 PM
Posted in error.
Old 06-12-2014, 08:46 PM
wfon's Avatar
Why are you posting the obvious? What is the point? Duh.
I give up.
Well you posted that as the spring gets warm it closes the valve. I think that is backward. The valve is supposed to be held closed when the engine is cold and as the engine and the spring warm up the valve opens. I was trying to point that out without being rude. Did I get that wrong?
Old 06-13-2014, 08:04 AM
My error. Corrected to note the spring gets weaker when warm, and allows the weight to open the valve.
tom
Old 06-13-2014, 05:40 PM
I give up.
Kinda rude...
Heat issue!! Michael9280 3.8 & 4.2L V6 1 09-26-2014 11:45 AM
6 cyl engine overheating in '66 F250 99hosss 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-09-2014 06:55 PM
leaking oil from exhaust control valve The Blue mule 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-25-2014 08:01 PM
Heat riser control ??? whisler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-09-2012 04:43 PM
ITS bad EBP SENSOR adamzelazowski 1999 - 2003 7.3L Power Stroke Diesel 18 05-30-2009 04:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
