Broken springs in front seat
Well not really springs, but the wire support under the cushion. Apparently it's just not designed to last 475,000 miles, even if you weigh in under 200.
Anyone know if a local dealer is likely to have this in stock? Any guesses as to what type of wire this is? Bends pretty easy with the fingers, but seems stiffer than would be expected for regular wire. Piano wire or such maybe?
I'd prefer not to mail order since I'd like to fix it over the weekend. Any suggestions would be welcome.
Drove over a bump and heard what sounded like a metal spring or wire snap in two. Then I was sitting in a hole. My guess is some were broken before and the bump finally caused several to snap at once.
Piano wire for a seat? Is that like an audible air freshener to counter offending sounds in that vicinity?
It's probably spring steel - very tough to bend or flex. Most other metals (like bailing wire or piano wire) will stretch and sag. Remember, piano wire and bailing wire are straight with tension... not on their own. That 1/2 twist at the end is not much of a grab - the wire is doing it on it's own.
I'm not too far from Ft Worth, but don't have a sewing machine and don't really feel like trying to sew it by hand. I drove around for 3 hours looking for something I could use. Looks like it will be plan B. Going to cut up some of those 1" straps and use some self tapping screws to fasten it into the seat frame.
