frustrated securilock no start and hottt pcm - Ford Truck Enthusiasts Forums
Old 05-30-2014, 03:18 PM
ddog86 ddog86 is offline
ddog86 is starting off with a positive reputation.
OK so my 2006 fx4 started doing the no start issue last yr in the heat of summer sometimes would start sometimes left me stranded..it was fine all winter an here we are in summer an once the truck is hot it will not want to start once ran then shut off. I have went through all the grounds an wires for shorts an found nothing. When I go to restart the light on dash blinks rapidly indicate the security stock system. No after hrs an headaches of tracking all this down I've only concluded that cooling down the pcm under the hood will start the vehicle...trust me it sounds seriosouly stupid but the only way it will start is pouring water onto the pcm because it gets so hot it'll almost burn you fingers..I do not understand why this works or how the pcm gets so hot...any info or leads on things to check would be much appreciated...I do not want to spend $$$$$ at ford to diagnose an tell me me bs.
PCM Diagram FourDead 1994.5 - 1997 7.3L Power Stroke Diesel 0 07-07-2016 11:08 AM
I need a VIN...or other ideas. Colorado350 1999 - 2003 7.3L Power Stroke Diesel 4 07-02-2016 07:06 AM
Chip / Tuning Connection Issues Spool&Go 1999 - 2003 7.3L Power Stroke Diesel 1 10-29-2014 11:35 PM
"Why is truck trying to stall/quit out on me?" hunter301 1999 - 2003 7.3L Power Stroke Diesel 59 04-04-2014 08:54 AM
PCM or fuel pump? jlgriff76 1987 - 1996 F150 & Larger F-Series Trucks 3 10-14-2013 02:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
