Harmonic Balancer - Ford Truck Enthusiasts Forums
Harmonic Balancer
Old 05-30-2014, 11:09 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Harmonic Balancer
In hopes of finding a double water pump pully, Im going to start with the balancer. I have a NOS balancer (C3TE-63TE-6316-E 3/8" double groove) that is listed for a 63-64 Ford Truck that had the option of a 2 belt generator. I swapped this balancer for the stock single belt dampner on my 56 F-250 272.
I found a double groove alternator that appears to have the same pully groove pattern as the balancer (approximately 5/8" center to center).
I am looking for a donar water pump pully that will match up or be close enough I can shim it. I have found several used three groove pullys but I do not want to use a three groove if I can find a two groove that will work.
The water pump pully I need is approximately 6 5/16" in diameter. Cant be larger or it will interfere with the generator/alternator bracket sold by John Mummert. The fan belt will rub in the bracket. The hub diameter of the water pump is 2 5/16" The shaft diameter of the water pump is 3/4". The mounting hole pattern is 4 hole and approximately 1 1/4" center to center on all four holes.
When I lay the pully face down and place a straight edge across the back, a tape should read a minimum of 2 9/16". If its more, I can shim it.
Im still searching wrecking yards and have inquiries on line about after market options, but nothing yet. It seems like if there was a double pully dampner option for a 63-64 truck, there should be a double pump water pully out there that would be the same belt groove pattern and offset that would bolt up.
1971 F250 power steering and AC conversion Pockets1187 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-06-2016 01:24 PM
Need pulley help!! Badmoonreizen 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-20-2016 06:34 PM
1963 292 Y Block Combatwombat 1961 - 1963 F100 Unibody 4 06-22-2015 09:46 AM
harmonic balancer noise? voodoosurfer Explorer, Sport Trac, Mountaineer & Aviator 14 03-01-2014 02:36 PM
Power steering pump brackets Shadowrider123 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-03-2012 11:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
