1995 California 5.8 PCM DPFE - Ford Truck Enthusiasts Forums
Old 05-30-2014, 11:41 AM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is online now
SteelHorse4x4 is starting off with a positive reputation.
Getting ready to start my MAF conversion and I'm coming up empty on one thing. My PCM came from a 1995 California Bronco 5.8. I don't have the harness from the truck, nor am I going to get a tuner right off the bat. I'm gonna change the truck over to a DPFE set-up for a while and see how it runs. I have the EGR, EGR tube for DPFE, silicon hoses, and a new DPFE with pigtail. What I don't have is a wiring diagram in either my 94, or 95 factory manuals that shows the DPFE on it. My 95 manual shows DPFE on pin 27 of the PCM, but when I go to the engine controls schematic, the wires are correct, but its labeled as EVP. Wiring "LOOKS" right and traces through to the correct pins (25-9 and 25-10) in the 1995 Bronco Wiring and Vacuum manual. Just trying to make sure before frying a new sensor. Thanks Guys.
Old 05-30-2014, 12:34 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
DPFE is an OBD2 thing and a '95 would have been OBD1 so you can't get there from here meaning you can't use DPFE components with this PCM.
Old 05-30-2014, 12:48 PM
Paul, thanks for the reply, but......... It is a DPFE set-up. Its the "California Unicorn". I lucked this PCM at Pick n Pull a few months back. Someone had already gutted the rest of the truck, but left the PCM. Come to find out, Its fairly sought after.
CALIBRATION: 5-64R-R10 5.8L MFI
Contents:
LHG (50 States) Decal
Calibration Parts List
Detailed Instruction View
Detailed Vacuum View
CALIBRATION PARTS LIST
NAME/DESCRIPTION
ENGINEERING NO.
SERVICE NO.
VALVE ASSY., (Thermactor Air By-Pass) F5TE 9B289-CA F5TZ 9B289-C
RESERVOIR ASSY., (EGR Vacuum) F4UE 9E453-CA F4UZ 9E453-C
CONTROL ASSY., (EGR Vacuum Regulator) F0TE 9J459-A1A F0TZ 9J459-A
SENSOR ASSY., (EGR Pressure Valve) F37E 9J460-AA F37Z 9J460-A
VALVE ASSY., (Thermactor Air Control Solenoid Vacuum) E7TE 9H465-AA E7TZ 9H465-A
SENSOR ASSY., (Exhaust Gas Oxygen) F39F 9F472-AA,AB F39Z 9F472-D
VALVE ASSY., (EGR) F4TE 9D475-A2A,A4A F4TZ 9D475-A
TUBE ASSY., (EGR Valve To Exhaust Manifold) F5TE 9D477-EA F5TZ 9D477-E
PUMP ASSY., (Thermactor) E8UE 9A486-BA E8UZ 9A486-B
VALVE ASSY., (Thermactor Check -- 3/4-14 Thread One End-Hose Nipple One End -- Upstream) F3TZ 9A487-C
INJECTOR ASSY., (Fuel) F2TE 9F593-A3A F2TZ 9F593-A
VALVE ASSY., (Throttle Air By-Pass) F4TE 9F715-AA F4TZ 9F715-A
REGULATOR ASSY., (Fuel Charging Pressure) F4SE 9C968-AA F4SZ 9C968-A
POTENTIOMETER ASSY., (Throttle Position Sensor) E7TF 9B989-CA E7TZ 9B989-D
DISTRIBUTOR ASSY.) E9TE 12127-CA F1TZ 12127-C
SENSOR ASSY., (Mass Airflow) F5UF 12B579-AA F4UZ 12B579-A
SENSOR ASSY., (Engine Electronic Control Coolant Temperature) F2AF 12A648-AA F2AZ 12A648-A
PROCESSOR AND CALIBRATOR ASSY., (EEC-IV) F5TF 12A650-TB F5TZ 12A650-TB
SENSOR ASSY., (Air Charge Temperature) F32F 12A697-AA F32Z 12A697-C
Old 05-30-2014, 01:00 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
According to my Ford manual Pin 27 is still the signal input from the DPFE sensor, same as the earlier EVP feedback EGR system.
Old 05-30-2014, 01:13 PM
Sorry, computer wouldn't let me rotate the images.
http://www.ford-trucks.com/forums/at...1&d=1401469799
http://www.ford-trucks.com/forums/at...1&d=1401469874
Yea, I was just hoping to find a diagram versus assuming they used the same wires, ya know. Helps get that warm and fuzzy feeling. LOL I know color codes and such are the same, so assuming isn't that far of a stretch.
Old 05-30-2014, 01:57 PM
rla2005's Avatar
This might help you sleep better:
Old 05-30-2014, 02:10 PM
It does. It shows even that series of truck uses the same coded wires as the EVP. Much appreciated.
DPFE plug wiring for 98 explorer 5.0 ewalt98 Electrical Systems/Wiring 6 09-24-2015 03:27 PM
removing EGR on 95 5.8 with DPFE sensor 95BroncoXLT5.8 1978 - 1996 Big Bronco 7 12-30-2014 10:17 AM
MAF conversion. SteelHorse4x4 1987 - 1996 F150 & Larger F-Series Trucks 9 05-28-2014 08:26 PM
On going lack of power and CEL icantdo55 1987 - 1996 F150 & Larger F-Series Trucks 9 01-29-2014 08:11 PM
2002 P0401 code and DPFE azallen 1997 - 2003 F150 0 06-02-2011 05:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
