Coolant help - Ford Truck Enthusiasts Forums
Coolant help
Old 05-30-2014, 11:18 AM
TinMan289 TinMan289 is offline
TinMan289 has a good reputation on FTE.TinMan289 has a good reputation on FTE.
Coolant help
I'm doing the flush portion of my egr delete/oil cooler replacement/turbo rebuild and I'm stuck on coolant. I've searched high and low but could not find any of the recommended types.
The only thing I could find is a red colored Zerex HD Extended Life formula...the top says recommended for CAT Cummins Detroit Diesel International Mack Deere and says "Diesel Ready".
It didn't say Ec-1 on it, but has a slurry of industry specs it meets.
Sound kosher??
Old 05-30-2014, 01:45 PM
vatreefarmer vatreefarmer is offline
vatreefarmer is gaining momentum as a positive member of FTE.
The Zerex HD Diesel Ready is what I'm using. My bottle does say CAT EC-1 on it however. If it helps, the UPC code is 2888250124. Their part # is ZXEDRU1 for the pre-diluted. I don't have a bottle handy of the straight stuff to give you that part #.
Old 05-30-2014, 03:10 PM
Thanks...I figured I had the right one, but the label is different than everything I've seen online. I checked on Zerex's website, I have ZXED1 - concentrate CAT EC-1 rated.
Happy now that I picked it up for just under $15/gal!
Old 05-30-2014, 03:41 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Yeah, that seams to be the best deal going for the EC-1 coolant -- I couldn't find the Zerex in my area so went with Final Charge -- about $10 more per gallon!
Zerex ELC bubba_78363 6.0L Power Stroke Diesel 15 01-23-2015 01:15 PM
How I miss thee Driver Jim General Diesel Discussion 1 07-23-2014 08:33 AM
1948 F5 M-H Snogo, I was told to come here and ask!:) Mack0238 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 12-27-2013 09:35 PM
coolant test strips--where to buy? One Sock General Diesel Discussion 4 12-18-2013 07:53 PM
Amsoil Coolant, Go or No Go? ndlawrence General Diesel Discussion 4 06-05-2013 09:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
