92 Ranger 4.0 - Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
92 Ranger 4.0
Old 05-30-2014, 10:18 AM
80351's Avatar
80351 80351 is offline
80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold
92 Ranger 4.0
Ok guess I have to do it this way, I have a 92 Ranger 4.0, the trans was going up in it do to the modulator sucking fliud out of the trans an into the engine. One night on my way home the engine overheated an blew the side tank off the radiator an it shutdown. I had it towed home an it hasnt run since. Do to the over abundance of oil in the crankcase the plugs were fowled so I replaced them, I'm getting spark an getting gas but it won't fire up even with starting fluid. When it cranks it doesn't seem like it has compression when it cranks but I checked 3 of the cylinders when replacing the plugs. Anybody have any ideas? Please keep in mind tools are very limited an a compression gage is not available. Thanks in advance for help gang.
Dave
What should I do about a 92 4.0 leaking oil so bad? 1998Ranger25L153CID Ranger & B-Series 3 01-06-2015 02:51 AM
92 4.0 X valve cover gaskets, Is it going to be expensive? 1998Ranger25L153CID Ranger & B-Series 2 10-13-2014 09:29 AM
Where do injectors get their signal on 92 4.0L ltlvt Ranger & B-Series 1 09-27-2013 09:54 PM
Ranger with 4.0L woes TheClev Ranger & B-Series 3 02-15-2011 01:00 PM
What is a code 28? dazzleaj Ranger & B-Series 4 05-22-2007 06:50 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
