1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Blower Motor
Old 05-29-2014, 10:00 PM
river_rat2008's Avatar
river_rat2008
river_rat2008 is offline
Blower Motor
I have a 2008 F350 and there is nothing blowing out of the vents or defrost for AC or heat. It doesn't matter what fan speed is set. Would this indicate a blower motor? Where exactly is it located and how to change?
Old 05-30-2014, 07:39 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
start with the easy stuff. Check the fuse and relay for the motor. Then, check the fuses in the SJB that power the temperature control unit. After that easy-to-check stuff, it's time to break out the meter and schematic and do some actual diagnostic work.
Old 05-30-2014, 11:18 AM
Mike189677's Avatar
Mike189677
Mike189677 is offline
Do you hear the compressor cycle when you select a/c? Do you have the manual or digital hvac controls? Wondering if maybe the blower motor resistor is burned up but usually with those some of the speeds will still work, believe those are under the dash in 08 quick Google search should tell yor for sure and give exact location.
Old 05-30-2014, 09:41 PM
projectSHO89
The compressor cycling has nothing to do with whether the blower operates.
If NO blower speeds work, it's not the resistor pack.
Thanks for playing.
Old 05-30-2014, 10:43 PM
Mike189677's Avatar
Mike189677
[QUOTE=projectSHO89;14393346]The compressor cycling has nothing to do with whether the blower operates.
Well aware of that was just wondering if it was coming on and that part of the system was working or if the whole system wasn't responding.
Thanks
Thanks for playing.
Your welcome.
Was just trying to get some more info not trying to be an hvac expert. Won't the compressor still cycle even if the blower wasn't working? Didn't mean to say that one was effecting or causing the other.
Old 05-31-2014, 05:30 AM
SC_Hoaty's Avatar
SC_Hoaty
SC_Hoaty is offline
Here is a link to a thread I did after I replaced mine.
https://www.ford-trucks.com/forums/1...placement.html
Old 05-31-2014, 09:35 AM
SC_Hoaty's Avatar
SC_Hoaty
SC_Hoaty is offline
Another tip - you can see it near the bottom of the first post in the thread I linked - pull the electrical connector on the fan and check it for voltage. If there is not voltage when there should be, then the problem is electrical. If that is the case, post it here and we can step you through a few checks.
If the voltage is present on the connector, but the fan won't blow, that is a pretty sure sign the fan motor is the problem. The thread I linked has step-by-step instructions for replacing it.
Old 06-01-2014, 06:12 AM
river_rat2008
Thank you. They are digital and you can hear that you are selecting different setting but nothing comes out of vents or defrost.
I will check the voltage this week. I'm hoping it isn't an electrical issue. That sounds like a nightmare.
Old 07-07-2014, 02:51 AM
river_rat2008
Motor
It was the blower motor. Put in a new one and good as new.
llh
2004 - 2008 F150
05-22-2019 05:47 PM
Texascowboy77
02-04-2019 07:18 AM
captain2207
1997-2006 Expedition & Navigator
08-25-2013 02:50 PM
Doug3524
07-18-2012 09:55 PM
Blakes3GreatDanes
05-08-2008 02:13 PM
Quick Reply: Blower Motor
