DRW tire filling
DRW tire filling
Had some parts lift over from my recent air leak repairs. Found this clip on valve stem filler at a Napa auto parts store.
The fittings and hose I had. This works real good for getting air into the tires, especially the inners.
The stem connector pops off like an automative air chuck.
I don't think he runs down the road with it. He just fills his tires with it. Hence the "quick release". I've never seen a quick release chuck like that for a tire valve. I'm having trouble understanding how the engagement of the coupler on the valve stem would work, but that could be because of visualizing how quick release airline couplers work. I hope he posts the part number.
I've never had a DRW (personally, work truck, yes) so I haven't commented, but this is what I was thinking. As often as tire pressure should be checked/adjusted, why not install something that will make it so much easier and is a permanent solution?
and what I think I am going to use
Wheel Masters 4-Hose Inflation Kit - 16" to 19-1/2" Dually - Hub Mount Wheel Masters Wheel Accessories WM8001
I will be adding tpms to them as well.
on
I was looking at the Milton kit here:
Question -
How do you add TPMS to our DRW trucks? I thought it was disabled with the DRW? Is there a switch somewhere or a setting that the dealer needs to change?
Nice looking kit!
Amazon.com: Milton S4006 Valve Stem Extension: Automotive
Question -
Question -
Nice looking kit!
Question -
Question -
Trucking System Technology |TST Trucking Systems (14 sensors total, 2 monitors)
you can disable the trailer sensors so they don't alarm when you are away from the trailer.
