DRW tire filling
I have a 4 sensor Tire Tracker
TireTraker Tire Pressure Monitor
but 1. needs to move to wake up the sensors, last time I was 15 miles away from home when the tire blew, and the sensor had not yet woken up. it did alarm when I started the truck after replacing the failed tire on the trailer.
2. can't turn off trailer tires. so when I am not using my trailer, I have to turn off the monitor.. had a nail in the inner of the dually,, didn't notice for a week.. bad..
3. can't leave the monitor plugged into power.. some battery problem.
so more times than not, its dead when I need it.
$219 +210 (dually sensors) for something totally not usable.
I have a miserable time with tires on my car hauler..
these guys have the best price on TST TPMS systems.
PressurePro, TST and Orange Tire Pressure Monitoring Systems "TPMS" for Cars, Pick-up's, SUV's, Motorcycles and RV's - Vulcan Tire Sales
To me that says, it will not leak for others, but will for me. So I decided to not bother trying. Lucky for me, I don't have to air up and down, just check on them. I take my air chuck with me, in case something unexpected crops up. But most likely if I am down significantly, it's because of a major problem, nothing I should air up and drive on.
Tire Minder is another system for monitoring tires. I use it on my trailer tires, but not on the truck, yet.
The reason I didn't, is because for every person that says they work great, you get another that says they tried 4 different systems and they all leaked.
... Tire Minder is another system for monitoring tires. I use it on my trailer tires, but not on the truck, yet. Amazon.com: Minder Research TMG400C6 Tire Pressure Monitoring System with 6 Transmitter: Automotive
I have a dickens of a time getting my air chuck and gauge on the inner tire valve stem.. I have tried 3 different brands, all behave about the same. maybe 1 time in 15 will they work. can't wait for the extensions!
They do look the same, but based on what you posted eariler:
My sensors are on all the time. I haven't moved the trailer for a couple of weeks. I can turn on the monitor and all the numbers are there. I have seen the air pressure go up during the day as the sun warms up the tires while camping. It's odd that we have different experiences.
They do look the same, but based on what you posted eariler: My sensors are on all the time. I haven't moved the trailer for a couple of weeks. I can turn on the monitor and all the numbers are there. I have seen the air pressure go up during the day as the sun warms up the tires while camping. It's odd that we have different experiences.
Andre,If you haven't already, you might want to take a look at this thread I had regarding getting in to check and fill DRW's. If you go through the entire thread, you will see, at least for me, I finally worked out a guage and an air chuck that work without having to get my hands in between tires or through the small holes.https://www.ford-trucks.com/forums/1...rw-owners.html
#28
Exactly. That is why I switched out to a 12 inch stem. Now I can reach the inner and outer tire valves without having to act like a contortionist.
#29
I'm with Wingdone on those braided extensions.
It isn't that they leak sitting there. It is that they are being whipped around in a big 2 foot diameter circle some 650 revolutions every minute. That's a lot worse than life in a front loading washing machine. Or a Frappucino blender.
That constant whipping, some 39,000 times every hour of highway cruising, can put some stress on those little whip hoses, even when the ends are retained by a clip.
There are two types of braided stainless steel valve extension kits
1. Pressurized, where the whip hose holds the same pressure as the inflated tire
2. Non Pressurized, where the whip hose has a flexible shaft inside that acts on the valve core in the wheel when the valve core in the stem is acted upon. This is what WheelMasters calls the "Live Stem", which I think was a tragedy in naming, because I thing of a live stem as being pressurized with air. So just know ahead of time that logic doesn't fly with WheelMasters. Their "Live Stem" is not live with pressure. It is a mechanical actuator, like a miniature choke cable.
The mechanical actuator is less likely to cause a radical tire failure than a pressurized extender. If the fittings and hose crimps get worked loose from centrifugal force, or if the extended hose gets severed, there is no air loss, as no air is held in this type of extender. It is of a newer design. I think it came out in 1997, if I recall correctly.
With the original design braided stainless pressurized extender, if you run over a piece of metal in the road, and it just so happens to curl up and sever the extender that extends between inner and outer wheel, that would lead to instant pressure evacuation of both the stem and the tire. Blow out.
I'd rather not have any of that stuff attached to the tires and wheels and hubcaps. If I need to check wheel nut torque, or remove a tire for a spare, or get to the brakes, I don't want to have to be dealing with hose holder cleats riveted to the wheel skins.
#30
Once I put my tire pressure sensors on, I decided to leave them on year round.
That eliminates physically checking the pressure. A simple scroll through the tire monitor is all that is needed now.
I adjust the pressure seasonally.
55 for the winter and 60 for the camping season.
I use the TST 507 system and am very happy with it. Customer service is excellent.
I'll get the Napa number, I plan on making a double so both tires can be inflated at the same time - pressure.
May even try a "four some"
