RDS auxiliary tank install
Decided the 65 gallon Titan was not enough so I installed a RDS bed tank.
Fits with an inch to spare under my toolbox.
I used a 3/8" solenoid controlled by Up-fitter #2 and a 1/4 turn valve in case of issues.
Had some USCG approved 3/8" fuel line as well as a variety of fittings, so I used that from the valve to the filler hose tee.
Tank is advertised at 45 gallons, manufacturers plate fixed to side of tank says 48 and I only got about 40 gallons in. Also changed out the cap to a non locking version.
The mounting fall right where the bottom of the bed is covered with a cross channel. Needed to use some weather guard blind nuts that I had.
Looks good. Too bad you couldnt have plumbed that solenoid under the bed for a cleaner look. 105 gallons. wow about a 1000 mile range when towing, 1800 or so empty.
I'd love more capacity, but dont do enough long haul driving that I'd worry about the fuel in a large capacity tank getting stale/algae, etc.
Looks good.
Dave
Looks good.
Dave
That looks really nice Porthole. I'm on my second RDS tank, this one is 60 gallons. So with my 40 gallon stock tank I do can do about 1,000 miles pulling or 1,800 miles empty. However to leave a little reserve I fill every 750 miles when towing.
I use an Airtex pump, 12V. shutoff valve, AuotMeter fuel gauge and Wix water filter/water separator. All of my appliances are mounted under the bed. RDS are the nicest people to deal with, great tech advice when you need them.
Now you can spend less time waiting in line to fuel up, and take advantage of lower priced fuel when you find it.
Happy travels!!!!
Jim
Happy travels!!!!
Jim
I have a similar set up but I'm using a straight gravity feed. That worked well in my 08 but the first time I filled the auxiliary the main stock ford tank leaked from somewhere. I tried it after the aux was down to half and it worked fine. This time I pumped 60 gallon (about 75 % full) and no leak. So I don't knw what is up with that.
Anyway, is the selenoid working as an ON/OFF switch for a gravity feed system? Or is it a pump? either way I may copy it. Thanks
I have been looking for an aux tank too.. go the other way, have 38, want 60 more.
so far all the tanks suck up 20 inches of floorspace. found a 70gal with the other profile. 10 inches of floor space, but too tall to put the bed cover back on.
I didn't like the idea of an electronic valve, but I guess its not so bad, your install is really clean.
I used RDS gravity feed setup with last RDS tank, on my 04 6.0. It always worked just fine. However, this time I got a little fancier with quicker transfer using the Airtex pump, and I monitor the aux tank with AutoMeter fuel gauge on left corner of my dash. I really love this setup. Two fuel stops for me Kansas to California.
Happy travels!!
Jim
Happy travels!!
Jim
Very nice tank install. I did the ALUMINUM TANK AND TANK (AT80R) with a Freedom Fill Auxiliary System. It is very similar to yours. I get about 1600 miles to a fill up with a total of 117-gallons of fuel. I use the stock long bed tank at 37-gallons and the 80-gallon in the bed tank.
Aux Tanks are a great investment in my opinion.
There is a lot of useful information of this forum for Aux Tanks.
The way I installed it allows for me to remove the solenoid from the top after disconnecting the fuel line in the event of failure.
Yes, I can reach it when standing on the Bully step. I will leave it closed most of the time, just open up for travel.
That's my plan anyway, and it may change next week.
Plus, where I work we have had 2 stations doing price wars reminiscent of the 70's. These 2 stations have been selling diesel 30-40 cents a gallon then all the other stations and no CC charge.
Over the winter I my go the route you did and add a pump along with some filtering capability and do plan on adding the fuel gauge.
I just bought an Airtex pump to make my 14 gallon fuel tote (gas for the RV generator) a little easier to use when I can't use gravity. Nice an quiet pump.
The 100-110 gallons total mean for 90% of our travels I can fill up before I hook up and re-fuel after we get home.
That is another reason for adding the valve, allows me to fill the tank and not have any issues with potential leaks
Done right it shouldn't leak - but **** happens.
This tank is 20" like you mention, but, it fits under my toolbox which was my goal.
