Stock Intake - Ford Truck Enthusiasts Forums
Stock Intake
Old 05-29-2014, 05:18 PM
Jens's Avatar
Jens Jens is offline
Jens is starting off with a positive reputation.
Stock Intake
Hello freinds,
does anybody know how to pull the rivets which hold the little pan under the stock Intake?
Is it a good idea to head up the area arround thr rivet with an flame?
I want to clean my spare intake and the accociated Heads which belongs to a '69 460 cid.
Thank you for your help
Jens
Old 05-30-2014, 12:29 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Years ago, I was about to center-punch the rivets and drill them out. Then I wondered how I would attach the pan again. I thought of tapping the holes, and using screws with some thread locker on them.
But after looking at it more, in my case, I decided to try to poke out and use a lot of solvent to remove all of the coked oil that was between the pan and the underside of the intake. I kept working at it and got it cleaned out pretty good.
I assume the purpose of the pan was to try to keep oil off of the hot underside of the exhaust cross-over passage in the intake.
As far as torching around the rivets, I wonder if that would be abusing cast-iron, would not want it to crack, or distort the shape of the manifold, or else it won't seal well to the cylinder heads, and end up with coolant leaks there. Those are my thoughts, anyway.
Old 06-05-2014, 12:57 PM
Jens's Avatar
Hello Torky2,
thank you for your response.
I am with you, the the purpose of the pan was to keep the hot oil off the hot underside of the cross-over passage, but I wonder why there ist not one or two drain holes to let the oil -which maybe reaches the inside of the pan -flows back into the engine before it will coking...
I also think that torching is not the best Idea as you wrote.
So the best way is to clean the manifold with lots of cleaning solvent (PF145)
Thank you very much and sorry for my english, it's not working perfekt at present day
Jens
Old 06-09-2014, 02:58 AM
Jens's Avatar
Hello,
Please forget what I wrote regarding the drain holes. I just found out that there are two drainholes, but in my case completely leakproof. I thought that was just a stamping in the pan.
thanks
have a nice week
Jens
Hole in intake plenum Cedarghost 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-21-2016 10:02 AM
4.0 SOHC, which Timing Chain Kit is good Quality? Ostbock-Jens 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 2 12-13-2015 07:29 AM
Dipstick placement in regards to the timing cover??? Penn79 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-25-2015 02:28 AM
1976 Ford f350 super camper special headers?? Penn79 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-27-2015 10:04 AM
Front Bed Panel Replacement? Smitty49 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-28-2014 06:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
