Ready Lift Stage 2 & bags?? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 05-29-2014, 04:52 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
So I am finally planning on getting my 20" wheels with 35's.....wife said I could get them for my birthday in July
So I am researching and I like the pricing of the ready lift stuff and it seems to be popular.
I have a 2012 CC 4x4 so I was thinking of the SST stage 2 kit but I also see the stage 3 kit that offers bigger blocks in the rear for their tow package.
Now I think I am going to put bags on my truck because when I load my 28' enclosed car trailer on it she squats pretty good.
So my question for those of you that have lifted your truck.....
Should I just stick with the stage 2 and bags?
If I spend the extra $100 on the stage 3 I think its still gonna squat the same amount and I will end up putting bags on any way....at that point what's the point of paying for the stage 3 kit????
Thoughts?
Old 05-29-2014, 05:32 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
I can't remember if you have the 250 or 350. I'd say based on that answer would dictate whether or not to get the blocks. The 250 is pretty close to level from what I recall so you'd definitely want the blocks if you're going up in the front (otherwise you'll be nose high).
I'm going to send you a PM regarding the bags.
Old 05-29-2014, 07:23 PM
Amelio's Avatar
yea its a 250 and its very close to level......all four corners are within a 1/2" of each other.
So from what you are saying I should go with the stage 3 kit.....it gives you the 4" blocks for a slight rake higher in the back.
The stage 3 TP kit comes with 5" blocks but I think that may be a bit much since I want the truck to appear level just sittin a few inches higher.
Am I correct on this?
Old 05-30-2014, 06:51 AM
I believe the 350's come with a 4" block, so with a 2"-2.5" leveling kit, you'll be pretty close to level. Might be worth measuring your stock block, then go from there. I went with a 2.5" Stage 2 ReadyLift kit on mine (no block change on my 350) and it's pretty close.
Old 06-01-2014, 06:43 PM
Amelio's Avatar
out of curiosity I measured my blocks...they are 2"
So I think I will go with the stage 2 Kit which comes with 2.5" spacers up front and 4" blocks.
I see that the stage 3 kit adds the addition of a carrier bearing spacer.....is this really needed?
Old 06-02-2014, 08:25 PM
I wouldn't get the spacer unless you notice some driveline shudder after you get it all done.
I'd hold out.
Old 07-20-2014, 08:52 AM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
Late reply have not been on in a while . I have the 5 inch block . Slightly higher with no trailer . . Im not a fan of level or nose high. Yes it has the shim for driveshaft Not sure about the 4 inch id say its like stock. . I like the idea of being slightly higher than the majority and looking stiock.
Single Stage Paint or 2-Stage Clearcoat Paint? LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 12-16-2016 08:27 AM
Stage 2 transmission green_95 1994.5 - 1997 7.3L Power Stroke Diesel 4 02-14-2016 10:04 PM
Thoughts on paint. Single Stage or Two Stage. restoringmy46 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-26-2012 02:01 AM
6 inch pro comp stage 1 and stage 2 4getfulbj 2004 - 2008 F150 17 07-17-2012 07:25 AM
Garrison Turbo Questions?? f-250diesel 1994.5 - 1997 7.3L Power Stroke Diesel 12 09-06-2011 08:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
