Garage door opener
#32
#34
Agreed, it's the car2u Leer setup that is giving people trouble. My openers are too new and require a module. My mom's are too old so I would need a module. Crazy. Homelink works with all openers and every other vehicle uses homelink. Not sure what Ford's deal is with Leer but wish it wasn't. So, now next to my fancy built in buttons, I have a standard clip on remote that came with the opener that works fine.
#35
#36
#37
#38
Do you have a steel insulated door? I don't think the signal strength is as strong as handheld transmitter. As I said in an earlier post, I had to get a converter to get the visor unit to work. But even so, my old handheld unit will open the door from half a block away. with my steel door, the has to be at the end of the driveway to open the and maybe 50-75 feet further away to close it. There is a slight distance differential with the handheld as but from much farther away. I believe the steel door has a slight blocking effect.
I always back in too. Have you tried pulling straight in to see if that makes a difference? Pulling straight in will get the transmitter closer to the house by a few feet.
2012 F-350 Lariat CC FX4 LB
#39
Here is a link to the page you need:
http://www.overheaddoor.com/garage-d...HD-openers.pdf
#41
I had the same problem. You can't use the programming instructions in the owners manual to program an Overhead door open. Go to the overhead door website and use their programming instructions. I did that and my visor remote works with both of my Overhead door openers now. The range still stinks, but at least it works.
#42
Got a call from the dealer today. Supposedly there is a fix for the radio issue that was released this week. My truck is scheduled for Thursday to be have new software installed to fix the radio not playing music unless you turn it off then back on when a phone is paired into the system. Will report back if it fixes the issue or not.
#44
#45
My house was built last year so my openers are newer models. I couldn't get the Car2u buttons to work following the instructions in the Ford manual, but I was able to use the instructions provided by Overhead door to make it all work.
