TS chip install quandary...
If you need a mirror, I'm guessing that you didn't remove the PCM for cleaning. You pretty much have to remove it to clean it properly. Your old chip/programmer, did you say it plugs into the OBD port and not onto the board where you're trying to put the TS chip? If that's the case, I think you need to remove the PCM and make sure you're getting it properly cleaned. It's next to impossible to do with it in the truck. Well, I shouldn't say it is i,possible, but it will take you longer than it would to remove the PCM, clean it properly, install the chip and reinstall the PCM. Pulling the PCM really isn't a big deal once you take the inner fender liner loose.
Thanks Nate, from what I've read the major difference was a little space ship like device near the fuel filter, the PCM, injectors, and a cat for 5spd trucks. I've also read that these trucks respond better than federal trucks to programming because of the splits. Can anyone recommend someone to burn some tunes on my chip who has experience w my situation? Also, just so I can make sure; w my vin # I should be able to call the dealer and ask what injectors came in my truck, correct?
EDIT; I've also read this morning that the cali trucks would throw a CEL after 25PSI and that a boost fooler is the way to go. Also, doesn't look like splits are any great advantage over singles. Am I loosing out on any great power gains staying w cali emissions as opposed to "federalizing" the truck?
#29
Yes, VIN should tell the story. And yes, the Cali trucks will respond somewhat better to tuning than a Fed OBS since you already have bigger fuel injection capacity (120cc Injectors vs our 90ccs). That should make for a nice running truck if you get the right tunes in it. There are a bunch of tuners out there, but I can't personally recommend one above another so I'll leave that to those who have personal experience in that regard.
#30
