Super Cooling vs. Camper Special Radiator
I am new to the Ford enthusiast forums. I have read several post from a couple different forums and in my opinion this site seems to have the most credible information (no offense to the other sites).
I have a question concerning super cooling radiators and camper special radiators. These are the large 24.25"x26.25" core radiators. One radiator has large wide brackets that start off close to the same thickness of the radiator and thickens as it moves to the top of the radiator. The next has brackets that are close to the same thickness of the radiator and then has a third flange in the middle of the brackets.
I am hoping to get everyone here that reads this post on which one is which. If anyone has an OEM (not aftermarket) radiator sitting in their vehicles and wouldn't mind posting a picture it would be greatly appreciated.
Also any additional information on these radiators would be greatly appreciated. Example: is there a version for 2WD vs. 4WD? Thanks in advance.
Jimmyzz28
Jimmyzz28
Thanks to ND https://www.ford-trucks.com/forums/8...ml#post7807146 What are you trying to do?
super cooler
super cooler
I am a design manager at a large radiator manufacture and we have a customer that ordered a radiator (supercooling of course) and he received our rendition of the radiator you see in the picture. He is insisting that it is wrong and it is a camper special radiator. I have been here eleven years and have not had that issue with one but my OCD kicked in and I want to make sure that we still know what we are talking about. That and we want to make sure that the customer is taking care of. Thank you for the perfect picture of what I was hoping to see.
Jimmyzz28
Jimmyzz28
Jimmyzz28
Jimmyzz28
Red,
I don't think I can post a direct link to our product here because we are not a sponsor. I have several different sizes of these radiators for these trucks. The core size are crazy as well as bracket placement. I will post to shop drawings of the super and camper units. Let me know what you think.
Really nice work ! oh and if you want to post the link cut and paste it and in the header remove the t's in http and replace them with x's we'll get it
I always thought though a 12v version of the fan design in this kick space heater running one top and bottom with the appropriate
shroud would be a much better way to cool
l
l
Jimmy, your desire to make sure you are doing your best to serve your customers is commendable and getting to be rare these days. Taking the time to register on this forum shows you have a commitment to your product and your customers. I for one would like to know the name of your company. I may be in the market for a radiator myself soon and would like to give your company and product due consideration.
Kudos to you!
Kudos to you!
l
l
If you search the numbers on the cad file you will find that these are available at Summit. I put a request in for real photos of this unit and I will post them here along with some of the other ones. We cover 20's up to the current Powerstroke units.
James
I have one more question for you guys regarding the smaller 19x26 core radiators. One has larger brackets built toward the engine and one has brackets toward the engine. I know that the uses call out for 2wd vs 4wd but I would like to know what the radiator is trying to miss in these applications. Thanks in advance.....
This would be a good read for you
Source : The FORDification.com Forums • View topic - Body swap to a 4x4
In a 4x4 the engine sits at a steeper angle in the chassis by about 1 degree. Doesn't sound like a bunch, but that is around 3/4" from the fan to the tail of the tranny. The 4x4 core support angles the radiator to match the engine angle better. The 2wd trucks with the supercooling option used the same core support as the 4x4's, but they used a different radiator. The supercool radiator will drop right in a 4x4 though
Whiplaunch
08-19-2014 11:54 AM
JIMMYZZ28
05-29-2014 12:07 AM
79er
11-05-2013 04:36 PM
jeff14346
08-27-2011 04:09 PM
