awkward broken spark plug - Ford Truck Enthusiasts Forums
Old 05-28-2014, 10:38 PM
theoneanonly theoneanonly is offline
theoneanonly is starting off with a positive reputation.
Alright guys i changed my plugs and if course had a couple broken plugs. Well one plug did not break how they normally break. All the porcelain is still in tack. Only thing that came off was the house that screws into the cylinder wall. I called lisle to see what i could do an the guy said good luck. So i was wonder has anyone had this problem an what did they do to solve it. Im not taking the head off. Feed back would be greatly appreciated
Old 05-29-2014, 11:45 AM
bgibbons60 bgibbons60 is offline
bgibbons60 is starting off with a positive reputation.
Not too bad
Had the same thing happen on 2 of the 8. I broke the 2 plugs with a screwdriver and pulled them out with a thin pair of needle nose pliers. I used the screwdriver and pryed the plug sideways. Just be careful that you clean the hole out again before extracting to prevent ceramic from dropping down in. You might have to twist back and forth when pulling it out. Then, use the lisle tool just as you did on the others.
Old 05-29-2014, 03:25 PM
Quote:
Thanks I just used some needle nose an came out. Came out fairly easy. I overlooked the problem way more than I should have
Another spark plug story milliesdad 2004 - 2008 F150 4 04-01-2016 07:31 PM
FICM SOLUTION BROKEN PLUGS cabinman 6.0L Power Stroke Diesel 30 12-03-2015 02:51 AM
85 f250 6.9 broken glow plug controller & antifreeze leak jp67 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 01-16-2015 08:54 PM
broken distributor rotor DHHD94 1947 and Older Ford Trucks 5 10-08-2012 04:31 PM
What spark plug tool for 2002 V10 2 valve neilc88 Modular V10 (6.8l) 7 06-23-2012 08:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
