Which grant mounting kit for the 1996 E250?
I had a grant wheel in my e150 1990, I liked it so much instead of the bearish big stock wheel. Wanted to mount in my 1996 E250 but the mechanic told after he tried, the mounting is different ( I haven't seen, i relied to the mechanic's statement ) so he didn't mount. Grant says it is the same, but the communication with them is anything but persuasive...Stupid situation. Does anybody know the truth?
Most likely your mechanic is correct----steering wheel fitment to a column with clock spring would be far different from its predecessors. Probably beginning in model year '92 this change began, whenever steering wheel airbags became standard equipment. To wit:
IIRC Grant's mounting system was/is geared more towards the older style horn button arrangement---not sure how that would or is supposed to work with the clock spring and air bags.
HTH
HTH
I can't see the pictures...but I understand what you mean. So probably there is no solution to mount the wheel i like. Or at least the info is not accessibile. It's a pitty. I hate this ship size wheel combined with a semit truck like gear ratio steering box. I got used about it but still would to change it on my van. I remember the first time when I drove my van i was shocked how many times I have to twist the wheel to make a turn
Any idea who is well informed about the ways to change the wheel for a smaller one? Maybe Mustang steering wheels can be ok? Are they any smaller? Same fitting?
jackburtonme
04-06-2016 09:19 PM
JapanE350bus
08-22-2014 06:56 PM
JRB65
02-05-2013 11:51 AM
GreatNorthWoods
16
02-09-2010 09:14 PM
