Center Brake light - Ford Truck Enthusiasts Forums
Center Brake light
Old 05-28-2014, 12:58 PM
roperchick roperchick is offline
roperchick is starting off with a positive reputation.
Center Brake light
My center brake light went out a month ago. Thought it was the bulb so replaced that, still didn't work. Checked the fuse and its not broken so my guess was electrical?
Hasn't come on once that I know of but I was randomly walking behind my truck and the light was on. Truck was off lights were off and key wasn't in the ignition.
Went and turned my truck on and turned the lights on and the cbl stayed on. When I switched my lights off it went out and stayed out.
Now I'm definitely thinking wiring but not sure where to start fixing?
Oh and it's a 1990 F150 XLT
Old 05-28-2014, 04:49 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Take the sill panel off and pull up the mat on the driver's side along the seat area and up the driver's side between the back of the door and the driver's side of the rear window. The wiring goes along this area, and sometimes corrodes and shorts out in behind the seat and along the bottom of the door sill area.
The wire you are looking for is a lightgreen wire. It comes right off the brake light switch on the pedal arm. It splits and goes to the steering column and straight up to your rear brake light. It also splits off and goes to the cruise system if you have that.
Old 09-03-2014, 11:38 PM
So turns out they didn't start putting cbl in these trucks till like '96 and mines actually the cargo light. Ha. My bad. I did fix the wiring though and it works now though.
Headlights won't turn on, got fog lights and running but goes off Ryan Stanowick 2004 - 2008 F150 1 01-13-2017 06:54 AM
ABS light ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 38 07-16-2015 06:16 PM
Brake lights staying on. Need help 79schaefer 1999 to 2016 Super Duty 7 06-05-2015 09:25 PM
running lights/park lights stay on rjorg Electrical Systems/Wiring 12 05-24-2015 07:18 AM
third brake light stays on(dim),after car is off probablecause Explorer, Sport Trac, Mountaineer & Aviator 1 01-15-2005 12:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
