F100 Kingpin replacement in Houston?
Old 05-28-2014, 12:22 PM
rwrogers's Avatar
rwrogers
rwrogers is offline
Anyone know of a shop in our around Houston Tx, that can swap out the kingpins? I have pulled the front suspension off a 76 F100 to put on my 66 F100, but would like to change out the kingpins first.
I've called around to a few shops, but havent found someone that can ream the bushings. They all say they can press them out and the new ones in, but reaming the bushings seems to be the hard part..
Old 05-28-2014, 01:43 PM
Macs1964F100's Avatar
Macs1964F100
Macs1964F100 is offline
I had mine done at Charlie's Trash Machine and Welding in San Antonio by an very old man in coveralls. He had to make a tool to press them and then lapped (sanded) them for an hour until they fit. Look for an old establish machine shop or speed shop. Most places look at you with a blank stare.
You might find the reamer on Ebay which would solve the issue.
Old 05-28-2014, 02:28 PM
rwrogers's Avatar
rwrogers
rwrogers is offline
Anyone know what size the reamer is for a 76 F100? I've looked around and there are several different sizes.
Old 05-28-2014, 06:21 PM
shortwide's Avatar
shortwide
shortwide is offline
Call James Newman at James Newman Automotive up in Conroe.
I don't know if he'll be able to do it, but he's an old school mechanic with an absolutely terrifying looking yard surrounding his shop (partially parted out cars and other misc junk literally EVERYWHERE). He's slow as Christmas and has the personality of a goat, but he's one of those mechanics who knows his stuff inside and out, and there's old stuff parked all in an amongst his hulks.
He'll tell you straight up whether he can or not.
4710 Old Highway 105 W, Conroe, TX 77304
(936) 588-6593
Old 05-29-2014, 07:44 AM
svolpone's Avatar
svolpone
svolpone is offline
LMAO. This should be his brochure.
Old 05-29-2014, 05:23 PM
429 f-100's Avatar
429 f-100
429 f-100 is offline
honing the bushings is easy here is what I used a simple cheap hone 15 -20 bucks at any auto parts store . stick it in a drill and 15-20 min or so per side and done easy peasy , the pins are a little bigger than 3/4 . the hard part will be getting the old stuff out!
jzjames
02-22-2016 10:45 PM
Schaffner
02-28-2015 06:41 PM
Diego113
12-12-2014 12:01 AM
rwrogers
1961 - 1963 F100 Unibody
05-28-2014 12:21 PM
tonyss96dcm
13
01-15-2009 12:40 AM
Quick Reply: F100 Kingpin replacement in Houston?
