Low idle and stalls
Old 05-28-2014, 10:43 AM
vinnyb541's Avatar
vinnyb541
vinnyb541 is offline
Low idle and stalls
hello my name is Vince i have a 2006 F150 5.4 that has some issues. the truck at low rpm's will start to shake and then will die. this only happens when its at low RPM's like pulling into parking spots. does anyone have any information about this problem? i have heard it could wither be a bad alternator or there is scaring on the cam shafts? any adive or knowledge on this problem is greatly appreciated. thank you. when it idles low it will almost sound like a diesel truck. the dealership says it could be scaring on cam shafts?
Old 05-28-2014, 10:49 AM
zweave's Avatar
zweave
zweave is offline
if you idle normal with your a/c off and not turning the wheel so no additional accessories are putting stress on the engine then it could be your IAC valve (idle air control)
Old 05-28-2014, 03:03 PM
critterf1's Avatar
critterf1
critterf1 is offline
Vacuum leak
08-11-2013 09:41 PM
streetlude95
08-21-2011 03:00 PM
9902ford
1997-2006 Expedition & Navigator
02-28-2011 01:20 PM
jethro b
Modular V8 (4.6L, 5.4L)
03-07-2009 06:14 PM
Quick Reply: Low idle and stalls
