Low idle and stalls - Ford Truck Enthusiasts Forums
Low idle and stalls
Old 05-28-2014, 11:43 AM
vinnyb541 vinnyb541 is offline
vinnyb541 is starting off with a positive reputation.
Low idle and stalls
hello my name is Vince i have a 2006 F150 5.4 that has some issues. the truck at low rpm's will start to shake and then will die. this only happens when its at low RPM's like pulling into parking spots. does anyone have any information about this problem? i have heard it could wither be a bad alternator or there is scaring on the cam shafts? any adive or knowledge on this problem is greatly appreciated. thank you. when it idles low it will almost sound like a diesel truck. the dealership says it could be scaring on cam shafts?
Old 05-28-2014, 11:49 AM
zweave zweave is offline
zweave is starting off with a positive reputation.
if you idle normal with your a/c off and not turning the wheel so no additional accessories are putting stress on the engine then it could be your IAC valve (idle air control)
Old 05-28-2014, 04:03 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Vacuum leak
IB autogroup app problems? Vince79vette Excursion - King of SUVs 11 11-12-2015 07:17 PM
Lowering t case for 8in lift? Vince79vette Excursion - King of SUVs 11 03-19-2015 07:10 PM
Heat issues Vince2307 1994.5 - 1997 7.3L Power Stroke Diesel 10 02-28-2015 12:16 PM
Odd Fuel Gauge Problem vince474 6.7L Power Stroke Diesel 9 09-02-2014 10:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
