Door hinge pins - Ford Truck Enthusiasts Forums
Door hinge pins
Old 05-28-2014, 10:28 AM
Wildebird's Avatar
Wildebird Wildebird is offline
Wildebird is starting off with a positive reputation.
Door hinge pins
Does any know the correct size or even where to get new door pins for my 1954 F100? I have purchased an oversized set which didn't fit(11/32"). I'm trying to avoid purchasing a new set of hinges. I thought I had the dilemma solved through Macs but their pins for the 53-56 F100 come to find out are oversized as well, although it doesn't say that on their website. Macs recommended just reeming the holes. I'm trying to avoid that if I can.
My hinges are in really good shape, it's just the pins are or were bent. Loads of fun to get them out. Any help would be greatly appreciated! I'm ready to paint the truck cab but would prefer to do it with the doors on. The firewall and door jams are already painted and ready for the doors.
If I have to replace the hinges has anyone used the adjustable ones? They seem pretty slick but just not sure if it's worth the extra $80.
Thanks
Old 05-28-2014, 10:58 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Just drill the hinges out to the proper diameter and install the new pins. I find it hard to imagine how pins could get bent without some slop/damage to the hinges.
Old 05-28-2014, 11:51 AM
Wildebird's Avatar
I can see your point, they are worn as well and I think that's where they seem bent. I guess it's from all the years of wrenching around the doors for alignment or whatever else. I'll check out the local machine shop.
Old 05-28-2014, 12:55 PM
CharlieLed's Avatar
No need for a machine shop, if the pins are 11/32 then just use that size drill bit and drill out the holes yourself. Easy peasy...
Old 05-28-2014, 04:30 PM
Wildebird's Avatar
Thanks, I'll give it a try, got a mechanic at work that feels pretty confident as well. Thanks
door hinge pins and adjustable hinges Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-24-2016 09:59 PM
Hinge Pin Bushings Gicknordon 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-19-2015 09:03 AM
Door Hinge Pins on a "53 F-100 jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-31-2014 12:44 PM
Reassembling Door Hinges ct50f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 08-18-2014 10:00 PM
door hinges joshofalltrades 1968-2013 Full Size Vans 4 02-10-2014 01:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
