Key won't go into ignition. - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 05-28-2014, 07:49 AM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
I came back from a long trip with camper, backed TT into barn and when I tried to start truck again the key would not go into the ignition, the dust door was jammed? My turnsignals would flash and a display said to insurt key to shut off alarm, I have no alarm? Power door locks and keyless entry worked fine, not sure if some kind of anti theft system was holding dust door closed? All my windows were down and the dealer wanted it towed in, with rain on the way I had to jam a screwdriver into key hole and bend the dust stop in to get the key in, truck started and I finished everything and took the key out and its working fine, the flapper returned to normal. I am dropping it off at dealer tonight for them to look at, hopefully they will change it out without saying it looks fine. I will be keeping that screwdriver in the truck from now on. Any one else heard of this?
Old 05-28-2014, 08:59 AM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
I have noticed my ignition to be "sloppy."
Please let us know the outcome.
Old 06-11-2014, 07:40 AM
The dealer kept the truck for 2 days and would only go and try the key every once and a while and said they won't take it appart unless it would not work for them. I would have to pay $275 to have it replaced and they would send it in to the war. dept. and if they find it bad they would repay me. Dealer had nothing to say about the alarm other than that can't happen as I don't have the upgraded alarm system?
Also when I turn my truck off the key reminder does not go off when I open the door with the key in the ignition.
I guess I am going to have to pay for the repair as I don't want to get stuck somewhere at a bad time, or I will just leave the key in the ignition and hang a rag over it to hide it and use the keypad to get in and out!!!!!!!!!!
Old 06-11-2014, 06:19 PM
So sorry.
I'll be having my ignition and my touch checked at my next oil change.
F350 radio,interior light,and gauges on off at will sjbahm 1999 to 2016 Super Duty 4 01-22-2017 09:42 PM
Starter or Ignition Switch? davbeisner 1997-2006 Expedition & Navigator 8 11-26-2015 11:55 AM
That annoying door chime is finally quiet! Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 130 07-21-2015 10:54 AM
How to stop the ding ding ding DOUG5G Ranger & B-Series 27 11-25-2014 04:49 PM
1992 F150 ignition lock cylinder removal VolvoMatt 1987 - 1996 F150 & Larger F-Series Trucks 5 10-09-2013 12:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
