Cracked valve cover driver side 2004 F150 - Ford Truck Enthusiasts Forums
Old 05-28-2014, 05:11 AM
Mike10157 Mike10157 is offline
Mike10157 is starting off with a positive reputation.
Exclamation Cracked valve cover driver side 2004 F150
I just had my transmission rebuilt on my truck 103k over drive went out because snap ring failed. That cost me 2200 but that isn't the issue after picking my truck up from the shop, hadn't even left the parking lot I noticed my engine light was now on. They hooked it up to the computer it was a cam sensor code. They said it'd be fine to take home and bring back after Memorial Day weekend, upon getting home I noticed burning oil smell and a lot of oil on the inside of my engine compartment on driver side along with it leaking on the ground. After the weekend I took it back they couldn't find the leak for hours then pin pointed it to a cracked valve cover right behind the power steering hose. Idk what to do I know I have to replace the valve cover but I'm just worried as to what caused the valve cover to crack. I can't see the timing chain having enough slack to crack the valve cover unless the guide is broke. Any idea on how this could happen? thoughts on what to do and the approximate cost of this fix?? Is it easy enough that I can do my self?
Old 05-29-2014, 12:05 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
the timing chain will break the valve cover mine jumped a tooth put hole in top of valve cover ran fine but leaked oil on ground and motor cause broken ten senor $ 1700 parts & lab.
Problem timing 2003 expediton 4.6 chambejp 1997-2006 Expedition & Navigator 4 07-04-2016 10:33 AM
oops...guess we we are dry camping now northwindone Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 17 06-22-2015 11:01 AM
How to replace valve cover gasket? JessieDM 1987 - 1996 F150 & Larger F-Series Trucks 17 02-09-2015 07:52 PM
92 4.0 X valve cover gaskets, Is it going to be expensive? 1998Ranger25L153CID Ranger & B-Series 2 10-13-2014 08:29 AM
Possible blown HG, need help to diagnose. dev_jhnsn 1994.5 - 1997 7.3L Power Stroke Diesel 23 07-16-2014 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
