Help, 92 F150 Rear ABS light, believe code 1 or 2? Youtube video linked.
Help, just bought a 92 F150 automatic with the straight six
when you turn the key to on, the abs light comes on, goes out for a second, then comes back on and stays on, does the same thing when you start it up.
I took a YouTube video showing this, and showing the codes that I tried to retrieve.
I checked the reservoir and it was full, so I thought maybe the sender in the reservoir was bad so I swapped it out for a good one, that didn't fix it either
Youtube video:
Youtube video:
