Low, quiet, abrasive sound coming from front end even while stationary
I have a 1994 f350, 7.5L, E4OD, 4x4 and it has a seemingly random and sporadic low pitched, pretty quiet grinding noise coming from the engine bay or front end somewhere. It doesnt always happen and I can't seem to notice much of a pattern for when it shows up except I do often notice it when the trucks climbing a hill. I figured it had something to do with the driveline because it comes and goes kind of like a bad bearing or something out of balance but I sometimes hear it while stationery with the engine idling. It even sounds like a driveline sort of sound, doesn't sound scary like gears grinding but more like a shaft spinning on a gritty surface for a second or two at a time. The truck definitely has an exhaust leak on the rear passenger area of the exhaust manifold like 7.5's like to develop. Is it possible an exhaust leak could make a sound that sounds like a low quiet grind? What else could be causing this sporadic sound? I'm leaning towards something in the engine as its got over 200k miles.
"Even when stationary I hear it" I had a bad smog pump that sounded similar and it is a somewhat common problem. Get a long screwdriver or a piece of hose and from the passenger side or front locate the pump at the bottom and listen to it especially when stopped. You will know if it is the issue. Always use caution when working on a running engine and park in a safe place.
n8mojo
02-26-2010 08:01 PM
Jet Lizard
04-06-2004 11:10 AM
