desperate held needed 460 - Ford Truck Enthusiasts Forums
Old 05-27-2014, 04:48 PM
gav2606 gav2606 is offline
gav2606 is starting off with a positive reputation.
hi all..i live in the uk and have a e350 cabriolet fifth wheel pick up..out of the blue it cut out..pulled over and restarted but it just keeps cutting out..rough idle sometimes but sometimrs runs like a clock..changed fuel pump..coil..carb..checked fuel lines..cleaned tank..changed plugs leads and cap..rewired coil..its got a dura spark 11 box..i believe it has a oil pressure safety system and fuel cut of but seems all ok..it does jump and splutter it just dies but still showing a spark and fuel..HELP please
Old 05-28-2014, 11:25 PM
fuzzybob's Avatar
fuzzybob fuzzybob is online now
fuzzybob is gaining momentum as a positive member of FTE.
Hello gav, Did you check the wires to the pick-up coil in the distributor? They flex as the dizzy advances and retards and sometimes crack and make a dodgy connection.
Good luck with it, Fuzzy
Is my PCM the culprit? OldGoldie 1987 - 1996 F150 & Larger F-Series Trucks 32 01-17-2017 09:28 PM
New distributor ? BKM-WR3 1987 - 1996 F150 & Larger F-Series Trucks 10 04-05-2015 05:06 PM
85 F350 460...no Spark! 90F250351 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 11-24-2014 06:25 PM
390 No Spark? Help Please!!! tjs_79ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 09-20-2009 12:30 PM
1988 f150 no spark no fuel nikolass Ford Inline Six, 200, 250, 4.9L / 300 6 07-19-2009 09:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
