flush coolant on a Ex V-10
Not mine, but great info and the V8 is pretty much the same as our V10.
2004 F250 5.4L Coolant Flush
That is really not a flush, that is just a drain and fill with a few cycles. To properly flush, you need to back flush the system, usually with some kind of forced air/water mixture via a flush gun similar to the one below.
Some more info:
http://www.caparadiator.com/coolingsysmaintenance.html
Some more info:
on
Do my flush, it works VERY WELL. The trick is to keep the garden hose in the tank while pressing the end of the bottom hose to the rad until the rad fills up and let loose about 3-4 times. Plan on getting wet.
https://www.ford-trucks.com/forums/1...al+clear+water
