P0430 - Ford Truck Enthusiasts Forums
P0430
Old 05-27-2014, 11:53 AM
ouikikazz ouikikazz is offline
ouikikazz is starting off with a positive reputation.
P0430
Hi I just picked up a 2006 F150 4x4 w/5.4 motor. It has 63,xxx on the clock and the 8yr/80k emissions warranty lapsed Feb of this year
In any case my truck threw a code the other day P0430, just that code, doing some research i can't seem to find a good solid answer on this...is itthe CATs or the O2 sensors (i believe that code reads for drivers side correct?)
My truck is smooth no misfires accelerates pretty smooth too. The CEL went off for a day then came back on so it's intermittent. spark plugs were changed in march (as per carfax) this is actually the latest entries of maintenance in carfax:
11/30/13
58,700 mi.
C and C Ford Chrysler Jeep Dodge
Horsham, PA
215-674-3600
Maintenance inspection completed
Tires rotated
Oil and filter changed
State inspection completed
Emissions inspection completed
3/18/14
63,536 mi.
Horsham, PA
215-674-3600
Battery/charging system checked
Tire condition and pressure checked
Throttle body cleaned/serviced
Fuel injection system flushed/serviced
Spark plug(s) replaced
Engine/powertrain computer/module checked
Alignment performed
Battery/charging system/starter checked
Induction system serviced
the dealer i bought it from had an oil change performed 2 months ago as per window sticker when it was put up for sale. Now i'm trying to find out what my best course of action is without dropping a few hundred on new cat and 2 o2 sensors. I live in NY so I NEED to pass emissions which i need to do in the next 25 days.
97 f150 4.6l cel p0430 ascaife 1997 - 2003 F150 8 05-13-2016 10:20 PM
2004 Escape XLT ground wire problem? stenscs Escape & Escape Hybrid 1 11-25-2015 05:48 PM
F250 Purchasing questions jukes23 1999 to 2016 Super Duty 8 11-24-2014 03:16 PM
2012 F-350 Advise dbh162 1999 to 2016 Super Duty 2 06-05-2014 11:22 AM
HELP 09 6.4L Died without warning! 73fan 6.4L Power Stroke Diesel 45 05-29-2014 06:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
