Power Steering Pump Bracket 79 F100 6 cyl - Ford Truck Enthusiasts Forums
Old 05-27-2014, 11:53 AM
scottness2 scottness2 is offline
scottness2 is starting off with a positive reputation.
Okay, I am restoring a 1979 F-100 (6 cyl 4.9L) and I want to add power steering. Finding the pump was easy - the bracket not so much.
Does anyone on the forum have a picture of the power steering pump bracket on an F-100 6 cylinder? That would help me get an idea if I can fabricate one.
In the mean time I'm still searching for one if anyone has any ideas of where to find one.
Thanks,
Scott
Old 05-27-2014, 12:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Here's the illustration from the Ford parts catalog.
The illustration at the bottom of the page, "C" is the 6 cylinder bracket.
Welcome to FTE, lot's of good people here, plus a few grouches.
Old 05-27-2014, 12:24 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Thanks,
Scott
Are you trying to put a saginaw pump on or is the stock braketry good for you ?
Old 05-27-2014, 01:31 PM
Mike - thank you for the picture. That's perfect. I was hoping it was one piece; it may be safer if I continue my hunt.
Redroad - I am looking to put in the stock pump. I pulled one in great shape off of a 302 but obviously the bracket will not fit. NOw that I know what I'm up against I will definately keep looking for one.
Thanks for the help.
Old 05-27-2014, 02:18 PM
redroad's Avatar
Don't lose the spacer when you pull it
Old 05-27-2014, 02:54 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1978/79 F100/350 300 I-6: There are two P/S pump brackets.
D8TZ-3C511-A .. P/S Pump Support Bracket / Obsolete
D8TZ-3A732-B .. P/S Pump Adjusting Bracket / Obsolete
No Ford dealer or obsolete parts vendor has either bracket.
Beginning in 1978: Ford changed the P/S pump on everything (except Econolines), it has a plastic reservoir.
This pump is a different shape than the steel reservoir pump used 1965/77. P/S pump mounting brackets used 1965/77 with the steel reservoir pump, will not fit the 1978 plastic reservoir pump.
The 1965/77 P/S pressure hoses won't fit either, as they thread onto the steel reservoir pump. P/S pressure hose connects to the plastic reservoir pump w/a qwik connect fitting.
Plastic reservoir pump used well into the 1990's.
Old 05-27-2014, 07:10 PM
Redroad. Great pictures. At least now I know exactly what I'm on the hunt for. Thanks for the tip on the spacer too.
Bill - and thanks for the part number verification (and crushing my dream of buying them online).
One way or the other I'll find them.
Drip rails for 73-79 F-100s ? scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-28-2015 02:40 PM
Metal and rubber line came loose 79 F-100 scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-23-2015 10:58 AM
AC Compressor bracket 79 F-100 6 cyl scottness2 WTB - Parts & other 3 05-07-2015 08:57 PM
Negative Battery Cable F100 6 cyl help scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-08-2015 10:07 AM
Need exhaust mani and power steering brackets for a 6 cyl 68fish WTB - Parts & other 1 10-05-2014 11:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
