How long can primer be left... - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 05-26-2014, 08:10 PM
Snipeston's Avatar
Snipeston Snipeston is offline
Snipeston is starting off with a positive reputation.
How long can primer be left without top coating? I need to do some rust repair on my 1995 F150 but plan on doing it in stages over the next 6-12 months. What primer would hold up best for this type of schedule.
Old 05-26-2014, 09:47 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Epoxy primer. You can leave it for years. They way that I do it is use it for a base over the metal after you've done your metal work. Then do your bondo and high fill primer and block it out. After you're happy with it top it with another coat of epoxy. You can also do your metal work, hit it with epoxy then come back later with bondo / high fill. If it's more than 5 days or so you need to scuff it and shoot another coat before painting anything else over it.
Southern Polyurethanes Home - Here's the stuff I use now. Their black primer has a UV inhibitor in it to last longer because so many people use it as a top coat. I used to use PPG Omni.
They also have a forum for all your paint questions.
As for high fill, lots of people like 2k, but I prefer a 1k. It doesn't dry as fast but they both build nice and the 1k lasts longer on the shelf. For a production shop I'd use 2k but for home and project use 1k. Just my preference.
Old 07-02-2014, 09:48 PM
postmortum postmortum is offline
postmortum is gaining momentum as a positive member of FTE.
I would agree Epoxy is the only primer to use if you plan on it sitting. I would go over that with a 2k after the body work, Epoxy is really hard to sand and has a low film build. A note tho with Epoxy you can't use any type of acid etch and make sure the metal is very clean before application. Epoxy is more sensitive to clean prep work
Old 07-04-2014, 06:53 PM
vtpkrat2 vtpkrat2 is offline
vtpkrat2 is starting off with a positive reputation.
I have used 2 stage epoxy primers (primer & hardner= 2 stage) in my body shop since they became available years and years ago.It sands EASILY and will withstand not being topcoated for a long period of time as opposed to single stage primer which is succeptable to attracting moisture as it sits. Do not go cheap on this layer as all the other coats of whatever are only as good as the weakest link. Good luck!
96 Eddie Bauer Bronco-deep paint scratch kirby1111 1978 - 1996 Big Bronco 5 02-01-2016 05:54 AM
Spray can primer or shop primer? mad103 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 01-30-2016 03:28 PM
Primers, etc jvmcc Paint & Bodywork 6 08-29-2013 09:31 PM
Primer question.... avf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 08-14-2013 06:25 PM
Black Primer/Flat Black 98powerstang Paint & Bodywork 10 01-27-2007 03:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
