1956 F250 OD Trans identification
Old 05-26-2014, 12:21 PM
bmann52's Avatar
bmann52
bmann52 is offline
I have what appears to be a 5 speed overdrive in my F250. According to the vin this truck had a 4speed all synchro.
This trans has 6 positions, 4 speeds, reverse and one at 12:00 that says "OD". Would this mean it came out of a heavy duty truck like a 500 or 600?
Old 05-26-2014, 01:23 PM
rustyrelic's Avatar
rustyrelic
rustyrelic is offline
Yes the 5sp overdrive was an option in f600 -f750 their were 3 versions, light, medium, heavy duty
The light duty overdrive had the following ratios
6.15
3.64
1.89
1.00
.798
6.00 rev
Old 05-26-2014, 01:31 PM
bmann52's Avatar
bmann52
bmann52 is offline
1956 Ford F250 Trans
6.15
3.64
1.89
1.00
.798
6.00 rev
That makes sense, thanks. Any key physical traits I could spot to pin it down? Anything bad about having this trans in the truck?
And BTW, its coupled to a Lincoln V8 with an ECM id no which shows it was off the same era - I guess either out of a Lincoln (valve covers) or out of a big truck as this is a Y Block engine which I guess they used in both.
Old 05-26-2014, 02:00 PM
rustyrelic's Avatar
rustyrelic
I've never actually seen one, but I wanted one very badly when I had the y-block ... so yes I think you have a very desirable engine / trans. combo.
Are you driving it yet? ..... picture's, we love picture's
BTW welcome to the forum.
Old 05-26-2014, 03:22 PM
bmann52's Avatar
bmann52
bmann52 is offline
1956 F250 Trans
Engine doesn't run - has been sitting A LONG time.
Unfortunately I'm going to have to sell it as my daily driver just blew an engine and I'm going to need the money.
Heres a few pics just for grins...
https://www.flickr.com/photos/124151559@N04/
Old 05-26-2014, 03:32 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Rusty_Old_F250 is offline
Looks like a decent truck! Shame you've got to sell it...
That shift pattern just screams clark 5spd.
Sam
Old 05-26-2014, 04:13 PM
bmann52's Avatar
bmann52
bmann52 is offline
Sam
It is a very decent truck and yes it is a shame. As for the tranny you've got me on that one - Clark 5 spd?
Old 05-27-2014, 12:02 AM
Rusty_Old_F250
Clark supplied heavy duty 5 speed transmissions to many of the medium duty truck builders, Ford used a lot of them, so did Chevy. They're a great transmission, just a bit heavy and slow shifting. You'll never break it though!
Sam
Old 05-27-2014, 03:03 AM
big job's Avatar
big job
big job is offline
Yes, the dead Clark give a way is 1st & rev is on the right and Spicers
1st & rev is on the left on both direct an Od 's -
the other Sam
Old 05-27-2014, 07:36 AM
38 coupe's Avatar
38 coupe
38 coupe is offline
The engine and transmission are a unit from a larger truck. The giveaways on the engine are the water pump and crank pulley, which are set up to mount a wide belt fan from the water pump. Hopefully someone here can purchase it, or the purchaser will join here. A very interesting truck.
Old 05-27-2014, 07:59 AM
bmann52's Avatar
bmann52
bmann52 is offline
Well thanks for all of your input. I had a feeling it was a large truck set up but its nice to hear that from the experts!
It also has an aux gas tank mounted under the bed which looks to me like a factory(?) or at least of that era option. Very sanitary with a large glass topped fuel filter mounted in line that looks like it could have been a large truck extra too.
cstempert
WTB - Parts & other
07-22-2016 06:10 PM
blatherskite
11-20-2003 11:46 AM
Franklin2
04-25-2001 09:30 PM
Quick Reply: 1956 F250 OD Trans identification
