Cracked AC Comp/Pulley Bracket
Well, just as I was reeling from my trans pan swap and service of trans, I found this problem (see pics)
The bracket (What is the Ford OEM name for this part?...it is not listed in service manual) is cracked near one of the mounting bolts. It appears to be a stress crack. It is cracked pretty good.
Has anyone experienced this? If so, what is entailed for removal replacement? Where can part be purchased? Hate to get another old one that has had years of heat and stress exposure.
Thoughts?
Thanks
Thoughts?
Thanks
Can the AC compressor be unbolted and lifted out of the way without having to disconnect the AC lines? I just serviced the AC system and do not want to incur another cost and inconvenience to have to do it again (It's not easy finding someone who services R-12 systems not to mention it is costly).
Anyone out there who may have taken this bracket off their engine and can explain the removal process?
It appears the power steering pump is bolted to the bracket. How are they separated...before removal or during removal of bracket?
My goal is remove bracket and have it TIG welded. I do NOT want to remove AC compressor or its lines.
I'm hoping someone out there has taken this bracket off before and can provide some guidance and tips on removal.
Thanks!
Thanks!
I don't understand the trouble you're having. The a/c comp, like any other engine-driven pump, is connected with flexible lines to allow it to move with the engine. These lines are long enough to get the compressor out of the way once it's unbolted. All you need to disconnect from it is the clutch wiring.
As for the steering pump, after you get the pulley off (requires pulley remover/installer tool) you can see the 3 bolts that hold it to the bracket. Your choice whether to remove it before or after taking the bracket out.
If you don't have the pulley tool, any AutoZone will rent it to you for a fully refundable fee.
Is that the "Orange Can of Death" I see?
Back to the point, as Dixie stated, use the power steering puller (Can be rented at parts store) and then set the pump out of the way. Then with the ac unbolted, the bracket is held in by 3 or 4 bolts.
May also be a good time to flush the Power steering system if you choose to.
Pulley Remover and Installer Set
Sure looks like one.
SoCal, you might wanna get that thing off your engine
If you are referring to the Fram filter, then yes. It was on when I purchased truck two months ago. The truck is not a daily driver. I have a Motorcraft FL-1A ready to go as soon as I fix this cracked bracket.
Since AZ doesn't charge for rentals ( fully refundable deposit), the $20 bucks for purchasing one at HF can't match AZ! I don't mind buying the tool if it works well but I don't anticipate using it very often.
gbakman
18
07-27-2017 06:38 PM
ccunni3812
04-03-2008 08:39 PM
