New member, another build.
#32
Except for the wind deflectora and grill (the 53 radiator mount horseshoe does not have the cross rod bracing but is otherwise the same/interchangable) all the front sheet metal is the same 53-56. The hood hinges are different, but the 56 hinges will bolt up to the 53 hood with the 56 shoulder bolts.
#33
As AXracer said everything is the same except the hinges and head light buckets.
In this picture with the old cab I was going to use a one piece air deflector and a 55 grill. With the 55 grill there is no need for head light buckets.
Here is the front sheet metal with a 56 air deflector with buckets.
#34
#36
#38
#40
#41
Is that the billet aluminum radiator cap from ebay?? or jegs...
http://www.jegs.com/i/Canton+Racing+...FU5afgodcQEAYA
#43
